Hesitation after gear change
waring192 Sep 17, 2010
  1. waring192
    waring192 Member
    349
    Hi guys, recently has my clutch (stock) replaced along with the DMF after the clutch "went". When I got the car back it has this hesitation after changing gear (never had it before). Its like its not fully engaged after the clutch is released but not like its slipping.
    Its been to Audi 2 been looked at and they can feel that their is a problem but all test show everything is running ok. After the looked more into it they found that it had been remapped and now think the map has something to do with it.
    It should be going in again next week to have the ecu re flashed back to original by Audi and see if its still happening.
    Any ideas in the mean time about what it could be?
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
  3. waring192
    waring192 Member
    349
  4. SAiLO
    1,078
    62
  5. waring192
    waring192 Member
    349
    Cheers, does sound just the same. I feel it 2nd,3rd and 4th though. Never had it before I had the clutch/flywheel changed.
    Mine should be going in at then end of next week to have the map taken off and retested. Im 99% sure its to do with the clutch/flywheel though.
  6. SAiLO
    1,078
    62
    I had clutch and flywheel changed and it started happening afterwards. Can't recall having that problem before. My car's also remapped, but I can remove it cause I've got bluefin.
  7. waring192
    waring192 Member
    349
    Yeah mines the same with Revo. I know bluefin completely removes the map though.
    Was yours done by Audi?
  8. SAiLO
    1,078
    62
    I had it done by a independent VAG specialist. Mine's 2.0tdi by the way.
  9. waring192
    waring192 Member
    349
    Have you asked them about it?
  10. SAiLO
    1,078
    62
    Not yet. Will try to unplug/change MAF and see if that affects anything.
  11. waring192
    waring192 Member
    349
    Cheers, let me know how you get on.
  12. waring192
    waring192 Member
    349
    Any updates? Doing abit of digging myself and notice a more of a noise when the clutch it not depressed. Also slight clunk noise when engage/disengaging.
  13. S3Alex
    10,826
    4,820
    HI...had no problems with mine after it was changed,and the only problems I remember seeing were those who had the DMF changed to single mass.
  14. waring192
    waring192 Member
    349
    Bit of a stage one:
    Put my original wheels back on and now the problem has gone?! Wheels are not buckled or anything at all. The Ck's where on before I had the clutch changed and there was none of this problem!
  15. Smoothie
    Smoothie Active Member
    1,431
    This thread just gets stranger and stranger, interesting read though....hope you guys get to the bottom of it
  16. SAiLO
    1,078
    62
    That's well strange. I'll till be changing MAF as soon as I get some time to do it.
  17. waring192
    waring192 Member
    349
    Yeah its very weird! Only thing I can think of is that while jacking its put pressure on something to go "into place"?!
    Would love if someone could shed some light on this?
