Here's a funny symptom.... my S3 has loose bowels?
Schlaag May 24, 2012
  1. Schlaag
    Schlaag Bwah
    472
    32
    Good morning
    I took the S3 for a spirited drive through the lanes last night en route somewhere (have just fitted a JR cone to the B5 TIP) and was pulling really well... i'm sure its not a standard map/boost level!
    anywho... obviously with the cone and TIP the induction noises are very noticeable.... however... every now and again on full throttle, the forge 008 would dump! without me letting off the throttle. How very rude!
    A loose scphincter perhaps? or more realistically a not strong enough spring in the 008 (I haven't changed it so its fitted with whatever it came with out of the box)
    OR, would it be this N249 bypass that i've heard banded around that needs doing? The S3 is AMK
    thanks
    Dave
  2. <tuffty/>
    20,903
    3,713
    It dumped and you lost power?
  3. Schlaag
    Schlaag Bwah
    472
    32
    Yes mate, just like I had let off the throttle. But foot was down. So at the moment im assuming weak spring in 008 or the N249 bypass should be done as the ecu is dumping my boost... the b*stard!
    thanks
    Dave
  4. Paradox1
    Paradox1 Active Member
    1,833
    88
    Was you on part throttle or really going for it
  5. <tuffty/>
    20,903
    3,713
    Sounds like limp mode to me... overboost or MAF issue typically... a scan for fault codes required methinks..
    N249 bypass would prevent the ECU from using the DV to dump boost when it thinks it has an issue but won't fix the reason why its happening... I would be looking to fix the issue first :)
  6. Schlaag
    Schlaag Bwah
    472
    32
    Limp mode eh! mmm cheeky. I had better get this VAGCOM gear bought sharpish then. Thanks again Tuffty
  7. superkarl
    superkarl MAN OF STEEL
    9,405
    2,379
    to me it sounds like esp is dumping the boost (what the n249 does)
    bypass that mother ****er
  8. badger5
    9,404
    1,944
    then it closes the throttle on you whilst the "event" is occuring..
    damned clever ecu's.. lol
  9. maundy26
    maundy26 New Member
    did u ever get to the bottom of this as my car does the same. cheers
