  1. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    If they are coming on when the car is cold then no they shouldn't as they are controlled by temp sensor. If you've been driving then I would say yes they will be on..............due to the heat of the engine.
  2. Chillout
    Chillout Active Member
    610
    50
    Is your coolant level ok i would advise you to get your car scanned if even just for peace of mind as you may have a dodgy temp sensor .
  3. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    My fans come on immediately when I take econ off.. It's normal we'll I assume its normal I have no fault codes!
  4. Chillout
    610
    50
    When econ is switched off that enables your a/c dependant on cabin temp and set point if the a/c is cycling to maintain your set point the fans will run however if you we're to put your heating up to full I would expect the fans to stop.
  5. OVRA3
    1,079
    80
    I don't think I've ever put the heating past 20 it's too hot lol! But yeah I'm sure they would as I said no fault codes so all must be well
  6. fangio
    fangio Well-Known Member
    1,520
    182
    I think I read that one fan cools the compressor when the air-con's on.
  7. fangio
    1,520
    182
    Who uses air-con constantly in Britain?:think:
  8. Jack_tdi
    Jack_tdi Member
    287
    12
    Stop worrying lol
    If there's no fault codes and the fans are running I wouldn't be too bothered...... Better than them not coming on
  9. fangio
    1,520
    182
    Oops! Missed that!:readit:
  10. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Stan, there is no logic in the fans coming on when the engine is cold, and the climate control is switched off. I suspect that one of your temperature sensors is not working to spec, and the engine thinks it's too hot. Get a VCDS scan as soon as possible and see what that indicates. Good luck.
  11. Chillout
    610
    50
    econ disables the a/c compressor as in economy less fuel used to run and will only use ambient air to cool the cabin
    while not on econ should your cabin require cooling it will use the a/c by running a/c your radiator fans will run to condense the discharge gas-to a liquid .
  12. Geraldy212
    565
    42
    Stan, when you first start the car, with econ = on, there should be no reason for the fans to start. If at any time you switch econ = off, then, depending on temperatures, the aircon (climate control) compressor will be active, and the fans may well start.
  13. Geraldy212
    565
    42
    Stan, with my A3, when econ= on, the fans are indeed off (when engine is cold)
    With econ = off, and 'Auto' =on, the fans will run fast or slow depending on the temperatures measured by
    the temperature sensors, and/or the cabin temperature settings. If the in-car temperature is high (on a hot day) and
    the temperature settings are around 20 deg C, the fans will run fast as one would expect. Hope this helps.
  14. OVRA3
    1,079
    80
    This thread is hilarious... Its normal mate you are being paranoid! :scared2:
    danb986 likes this.
  15. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    345
    61
    It has been stated above by chill out, for those who dont know your air con has 2 heater matrixes one within the cabin (evaporator) to soak up the warm air (giving an illusion of cold air coming out of your vents), and one behind your radiator to discharge the hot air (Condensor). So when your air con is on (Econ not selected) and your not moving the matrix behind your radiator still needs to dissipate the heat it is dragging out of your cabin, so the fans will run, creating the airflow.
    Hope this helps!
  16. fangio
    1,520
    182
