Help !!!
gtvlew Mar 20, 2013
  1. gtvlew
    gtvlew Member
    67
    Locked car on fob about 2 hrs ago, knock on door neighbour tells me car alarm going off very quietly with hazards flashing aswell, went to konock it off on key fob Nothing happens, tried spare keyfob still same, unlock car with key alarm still going, started car ok all hazrds and siren stopped.
    both fobs not working, locked car on key, 30 secs later same again lights flashing and siren very quiet.
    I aint got a clue !!!! regards Gary (car is bex 190 quattro)
  2. Andie0
    Andie0 Member
    490
    13
    Have you tryed messing with the buttons in the pocket in the drivers door?
  3. gtvlew
    gtvlew Member
    67
    No just locked the car on the fob earlier this evening and now this has started
  4. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    590
    I would open the bonnet, lock all doors on the car, disconnect the battery, and deal with it tomorrow in the light if you can
  5. gtvlew
    gtvlew Member
    67
    Right i found this and it works a treat, the only problem when ive programmed the first fob, when i swap the fobs around to program second one after the second fob is programmed the 1st fob stops F********g working arghhh!!, so ive got my main fob working now but the spare does not. this is info i found
    1. Take the spare key, put it into the ignition and turn the key to the "on" position, just prior to starting the car.
    2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
    3. Exit the car and close the door.
    4. With a second key, physically lock the doors (don't use a remote).
    5. Take the first remote to be programmed, press one of the buttons and the lights will flash once. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed
  6. gtvlew
    gtvlew Member
    67
    will try this in the morning for second key
  7. gtvlew
    gtvlew Member
    67
    Could'nt wait till morning both fobs now working very strange why it happened in the first place
