  1. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    driveing down to south wales today on the M50
    car starts ****ing about loss of power jumping around
    turned off back on drove ok for a few miles
    did same again pulled over cut out.
    will start after a good cranking but revs bad and cuts out
    got recovered back to sunny sheffield
    and got these 2 codes
    16485
    16683
    iv read them up on rosstech wiki
    but could either 1 of the faults stop the car running ?
  2. hades-
    9,480
    646
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Control Module Part Number: 03G 906 016 GN HW: 028 101 211 3
    Component and/or Version: R4 2,0L EDC 0000SG 9618
    Software Coding: 0000072
    Work Shop Code: WSC 00783 210 91542
    VCID: 75EA0B3F1CDA171
    2 Faults Found:
    16485 - Mass Air Flow Sensor (G70)
    P0101 - 000 - Implausible Signal
    Freeze Frame:
    RPM: 1323 /min
    Torque: 0.0 Nm
    Speed: 67.0 km/h
    Temperature: 54.0°C
    Mass Flow: 15.64 g/s
    (no units): 1.40
    Temperature: 90.9°C
    16683 - Boost Pressure Regulation
    P0299 - 000 - Control Range Not Reached
    Freeze Frame:
    RPM: 2856 /min
    Torque: 184.0 Nm
    Speed: 44.0 km/h
    Load: 77.6 %
    Voltage: 13.83 V
    Bin. Bits: 11000000
    Absolute Pres.: 2305.2 mbar
    Absolute Pres.: 1295.4 mbar
    Readiness: 1 1 0 0 0
  3. NHN
    29,284
    1,695
    Check air mass meter is plugged in ok as may have come unplugged & yes mass air can affect this as affectively its telling ecu air flow & adjust fuel accordingly.
  4. hades-
    9,480
    646
    1st thing i checked
    still the same when unplugged
  5. NHN
    29,284
    1,695
    Urm sounds like maf is buggered, can you check if its getting any flow registering in measuring blocks with vcds?
  6. hades-
    9,480
    646
    sorted was this lil fukker
    unplugged it car started and ran
    checked MAF was spot on.
  7. NHN
    29,284
    1,695
    Boost sensor, maybe not a good idea to run car without that working, as that effectively would not show boost levels correctly, maybe ok but I wouldnt want to risk incorrect boosting transmitted to the car systems.
  8. hades-
    9,480
    646
    im not running it
    was unplugged to find the fault
    left it in the garage till i get 1 in the morning.
  9. NHN
    29,284
    1,695
    Fair enough :)
