  1. Wozski
    Wozski Member
    508
    Just had a blonde moment and whilst i was checking my coolant level and washer levels i accidentally put no more than 100ml of screen wash intothe coolant tank!
    Am i ok or do i need to drain the tank?
    If so how do i do it
    thanks
  2. PilotAudi
    PilotAudi New Member
    2,352
    479
    Silly Bugger!! and you support Swansea!!!:sadlike:
    Not sure if it's a problem but I would doubt it... If you are able to find some hose, small bore winemaking stuff is ideal.. you can suck gently and let gravity do the rest and get rid of what you can.
    I wouldn't think it is an issue though as I would imagine it has some of the same properties as Anti Freeze.
  3. Wozski
    Wozski Member
    508
    Nowt wrong with the swans - i could live say in bristol and support man ure ;o)
    Thats a good idea about draining it with a pipe - will try it now
    BTW who do you support?>
  4. sub39h
    sub39h Active Member
    2,502
    i'd imagine it would be wisest to flush the system.
    screenwash is similar to coolant, but it's got soap in it and lord knows what that'll do to the cooling system. it's probably in a small enough concentration to not matter, but i wouldn't risk it personally.
  5. Wozski
    Wozski Member
    508
    Just spoken to an audi mech and he says its ok - so phew!
  6. antmax7
    antmax7 Member
    295
    all the fuss about mixing diff brands of coolant
    but screen wash will be OK
    sorry i don't buy that personally but its you car do with as you wish
    i would flush the system personally as forĀ£30-40 its gonna cost you it ain't worth risking it!
  7. PaulTheo
    PaulTheo Member
    126
    If you have not run the engine draining the header will get at least 90% of it out. The amount left would be very small indeed.
  8. Wozski
    Wozski Member
    508
    Twas only a minimal amount anyway
    Thanks for your advice
