Help with Xenon Plus lights Tourist Mode 2012 A3 Sportback Black Edition 1.8 TFSI
amoxitine Apr 24, 2013
  1. amoxitine
    amoxitine New Member
    Hi there,
    I have purchased a VCDS cable from VAG Diagnostics (VAG Diagnostics Ltd - VCDS Vag-Com 908, 912, & 10.6 Cables) in order to switch my headlights into Tourist mode so that I can drive on the right when in France, but having problems trying to do this as when I select the control Module '55 Xenon Range', choose Adaption 10, then select the channel called 'Activate left/right hand drive switch-over' it only shows the stored value as 'Unknown' rather than inactive/active. The cable comes with v10.6.4 of VCDS but I cannot use any other version as it says if I do then it can damage the cable itself.
    I did spot an old post in the A3/S3 forum (http://www.audi-sport.net/vb/a3-s3-...ve-switchover-2012-xenon-plus-headlights.html) and I think I may have the same set of headlight as the guy who opened this thread, as when I look in the log I took the Xenon controller number is the same. As a total newbie to all this I couldn't understand after reading that thread whether I was snookered or that there is a way to make the change to tourist mode, but not in the way you would normally do it (as I outlined in the paragraph above)
    If anyone could give some advice to a total novice to all of this and let me know if I'm totally wasting my time with the cable and version of VCDS I have bought to use with my particular model of A3 I would be grateful.
    Here is a copy of the log I took if this is of any use?...
    Cheers,
    Dave
    Tuesday,23,April,2013,00:06:11:37412
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 61 62 72 77
    VIN: WAUZZZ8P2DA021173 Mileage: 7660km/4759miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CDA) Labels: None
    Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
    Component: 1.8l R4/4V TFSI 0040
    Revision: AAH18--- Serial number: AUX7Z0L6FN40C2
    Coding: 0143000C18070060
    Shop #: WSC 06314 000 00000
    VCID: 418334A06119
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 13424012492400FBC80C02EB921C0081380800
    VCID: 7CFD8554467B
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
    Component: KlimavollautomatH09 0180
    Revision: 000922 Serial number: 8P0820043BM
    Shop #: WSC 00000 000 00000
    VCID: 78F599447243
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 110 0667
    Revision: AJ110667
    Coding: 4E000A2FA005F0C0207041E00000095C421E2BAA304DD928E4000E840041
    VCID: 3F87325817ED
    Part No SW: 8P2 955 119 F HW: 8P2 955 119 F
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Part No: 8P0 951 177
    Component: Innenraumuebe H04 0020
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Part No: 1K0 907 719 C
    Component: Neigungssenso 005 0003
    Address 15: Airbags (J234) Labels: None
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H10 0250
    Revision: -------- Serial number: 003JU007VBT1
    Coding: 30314238303830303037554A305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52A10BECB47F
    Driver's Airbag Crash Sensor:
    Serial number: 3572DRB40000EB48AA77
    Passenger Side Airbag Crash Sensor:
    Serial number: 3582DRB40000EB488A32
    Driver's Rear Airbag Crash Sensor:
    Serial number: 35128RB400006BBA101F
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 35228RB400006BB9F6A1
    Driver's Front Airbag Crash Sensor:
    Serial number: 35547RB400006C39E49.
    Passenger's Front Airbag Crash Sensor:
    Serial number: 35647RB400006C39E7D2
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H38 0070
    Coding: 0004012
    VCID: 468927BC4837
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: None
    Part No SW: 8P0 920 983 J HW: 8P0 920 983 J
    Component: KOMBIINSTR. VDO H03 0360
    Revision: D0H03004 Serial number: 2246L004000697
    Coding: 0260428
    Shop #: WSC 17328 000 1048576
    VCID: 418334A06119
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
    Component: J533 Gateway H43 1632
    Revision: H43 Serial number: 260612F1000648
    Coding: 352103
    VCID: 408531A46A13
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H03004 Serial number: AUX7Z0L6FN40C2
    VCID: 418334A06119
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
    Component: Tuer-SG H04 0101
    Coding: 0000692
    VCID: 49932C805929
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 232 3305
    Revision: 00H22000
    Shop #: WSC 02069 000 90108
    VCID: 37775A783FDD
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
    Coding: 0000692
    VCID: 4A91138C5C2F
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
    Component: ****LWR12**** H02 0012
    Serial number: 120619-0002-157
    Coding: 1163951010000000
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic.rod
    VCID: 42813BAC641F
    Address 56: Radio Labels: None
    Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
    Component: R Concert2+ H06 0293
    Revision: 00H06000 Serial number: AUZ1Z3M3175407
    Coding: 0710101
    VCID: 72E1AB6C143F
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 7N0 907 530 J
    Component: Batt.regelung H43 1632
    Coding: F326085A
    VCID: F1E324609139
    Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    VCID: 42813BAC641F
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0000144
    VCID: 438F3EA87B05
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005557024
    Coding: 0001222
    VCID: 356B507025D1
    End ---------------------------------------------------------------------
  2. Gizmo68
    Gizmo68 VCDS owner in Kent VCDS Map User
    88
    You have a cable running (old) hacked software, this is the reason you cannot update it, the hacked software pre dates your cars software, this is going to be your biggest stumbling block.
    Personally I wouldn’t connect any hacked software into a £2K car… let alone a £20K+ one, however it is your car and your choice.
