Help with VAGCOM codes
Madeley Jul 4, 2010
  1. Madeley
    Madeley Member VCDS Map User
    125
    Morning all,
    I would like to say a_big_thanks_to_pns2007_for_taking_the_time_to_plug_it_in:rock:
    Heres_the_results
    First_time_he_pluged_it_in-
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine Labels: None
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 66565
    VCID: 3874D6E5323B
    WAUZZZ8LZ1A039621 AUZ7Z0Y1613559
    8 Faults Found:
    17939 - Camshaft Timing Adjustment: Open Circuit
    P1531 - 35-00 - -
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-10 - - - Intermittent
    16487 - Mass Air Flow Sensor (G70): Signal too High
    P0103 - 35-10 - - - Intermittent
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    17695 - Boost Pressure Control Valve (N249): Open Circuit
    P1287 - 35-10 - - - Intermittent
    16711 - Knock Sensor 1 (G61): Signal too Low
    P0327 - 35-00 - -
    16716 - Knock Sensor 2 (G66): Signal too Low
    P0332 - 35-00 - -
    Readiness: 0000 0100
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 00628
    VCID: 2F66EDB9C775
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Interior Lights
    28-00 - Short to Plus
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C4DE854A2B
    3 Faults Found:
    01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
    27-00 - Implausible Signal
    01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
    01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
    35-00 - -
    End ---------------------------------------------------------------------
    Fourth_time_after_clearing_codes-
    VIN: WAUZZZ8LZ1A039621
    Coding: 10710
    Shop #: WSC 66565
    VCID: 3874D6E5323B
    1 Fault Found:
    P1531 - 35-00 - -
    Readiness: 0110 0101
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 06435
    VCID: 3E78C0FD101F
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    57-00 - Electric Circuit Failure
    00778 - Steering Angle Sensor (G85)
    62-00 - No or Incorrect Adjustment
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 J
    Component: A3 KLIMAAUTOMAT 0101
    Coding: 00041
    Shop #: WSC 06435
    VCID: 2F66EDB9C775
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 4008
    Coding: 01104
    Shop #: WSC 06435
    VCID: 458AAF1175C9
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 L
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 01442
    Shop #: WSC 00628
    VCID: 3C7CCAF50603
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F461D79B7D5
    Coding: 15178
    Shop #: WSC 00628
    VCID: 2F66EDB9C775
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C4DE854A2B
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 06435
    VCID: E5CACF915509
    The_one_that_stands_out_is_17939 - Camshaft Timing Adjustment: Open Circuit.
    I've_read_it_could_be_the_a_relay_or_sensor,any_one_shed_any_light_on_this?
  2. Madeley
    125
    Can_anyone_help,l_can't_find_out_what_this_code_means_its_not_even_on_the_ross_tecs_site.
    P1531 - 35-00 - -
  3. NHN
    29,354
    1,720
    Yes he is a very helpful chap.
    Alot of engine errors there, alarm ones do popup & are minor overall.
    It would signify a broken connection, you need to check the wiring schematics & as you say any associated relays/fuses.
  4. finesse
    finesse Active Member
    2,805
    oh dear, never seen so many errors, you are about to spend some cash
  5. pns2007
    pns2007 Moonstone Grey VCDS Map User
    686
    62
    Hi Dave (Madeley) Hope you get it sorted. A lot of error codes but we managed to clear quite a few.
    One fast car there mate, had to change my underpants after the demo lol
  6. Madeley
    125
    I'll give you a update this weekend neil, thanks for your comments people.
  7. Madeley
    125
    P1531 - 35-00 - -
    Found the problem, l got the wrong engine in her.
    My car is a 2000 face lift s3 2001 model that should have a AMK(says in the boot) but some one has put apy engine in.
    What l need to no is could i fit a vvt actuator to a apy engine, or can l get it mapped out? as its built into the apy.
  8. finesse
    2,805
    apy ecu maybe?
  9. Madeley
    125
    Would it be a Audi job to change the ecu and program it to the car, would be nice just to drop a apy ecu straight in.
  10. NHN
    29,354
    1,720
    Uh yeah audi would be 1 port of call, immo etc has to be setup for it aswell I should think.
