I got a a3 2.0fsi 2003 starting from cold is no issue but try restarting 10 mins later and it's a ****** to start,drives fine until it warms up then hit 3k and want to miss fire and die but I lift off throttle it's fine then hits 3k and it misfires again would that be due to cam sensor and nox sensor?
The power steering works wen it feels like it after I cleared to code it worked shut the car off and go to restart it it's losing power again guess that esp control unit?
And my fans come on from start up and won't let the temp gauge rise and run for 10seconds after Ive shut the car off.
Here's my report
Date: 31 Oct 2016 19:34
Subject: audi faults
To: <garyfewings1978@gmail.com>
Cc:
Monday,31,October,2016,19:32:54:24915
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8P24A010738 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 76
VIN: WAUZZZ8P24A010738 Mileage: 189870km-117979miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 06F-906-056-AXW.lbl
Part No SW: 06F 906 056 S HW: Hardware No
Component: MED9.5.10 G00 5201
Revision: 00000000 Serial number: AUX7Z0C3FNT088
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 397CA1F77038C18ABB-806C
Subsystem 1 - Part No: 06F 907 807 A
Component: NOX 0304230195 004 3608
06F907807A NOX 0304230195 004 3608
4 Faults Found:
17480 - NOx Sensor (G295) Heater Control
P1072 - 008 - Circuit Malfunction
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal
16575 - Fuel Pressure Sensor (G247)
P0191 - 008 - Implausible Signal - Intermittent
18068 - Coolant Fan Control 1
P1660 - 002 - Short to Ground - Intermittent - MIL ON
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0053894
VCID: 336093DF52543BDA71-8066
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 C HW: 8P0 820 043 C
Component: KlimavollautomatH11 0120
VCID: 2C5288A38F6A642230-8078
4 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 45
Mileage: 189694 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:28
Freeze Frame:
Voltage: 8.80 V
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 189847 km
Time Indication: 0
Date: 2016.08.24
Time: 04:35:08
Freeze Frame:
Voltage: 13.50 V
(no units): 155.0
Temperature: 11.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 131
Mileage: 186864 km
Time Indication: 0
Date: 2014.11.20
Time: 00:03:54
Freeze Frame:
Temperature: 18.5°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 159070 km
Time Indication: 0
Date: 2013.09.21
Time: 00:52:47
Freeze Frame:
Temperature: 20.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006404311
Coding: A78EDF00A0141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B70BBFF7A04F39AA9-806E
Subsystem 1 - Part No: 8P2 955 119 Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
5 Faults Found:
02104 - Light Detection Sensor (G399)
01320 - Control Module for Climatronic (J255)
00466 - Control Module for Steering Column Electronics (J527)
00906 - Horn (H1)
009 - Open or Short to Ground - Intermittent
00834 - Signal for Activation of Heated Rear Window
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 4584DD070CC0B56ACF-8010
No fault code found.
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H07 0020
Coding: 0000042
VCID: 7BF07BFF3A84339AE9-802E
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 JX HW: 8P0 920 980 JX
Component: KOMBIINSTR. VDO H25 0160
Revision: D14 Serial number: 2249ED14000535
Coding: 0004403
Shop #: WSC 06795 067 57207
VCID: 16264A4B21E6CEF276-8042
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H07 0040
Revision: 07 Serial number: 15000134152D43
Coding: 7D0F0740070101
VCID: 26467A8B91865E72E6-8072
3 Faults Found:
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 48
Mileage: 187722 km
Time Indication: 0
Date: 2015.09.20
Time: 00:14:28
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Reset counter: 8
Mileage: 187722 km
Time Indication: 0
Date: 2015.09.20
Time: 00:14:28
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 8
Mileage: 187722 km
Time Indication: 0
Date: 2015.09.20
Time: 00:14:32
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D14 Serial number: AUX7Z0C3FNT088
Shop #: WSC 00778 210 81005
1 Fault Found:
01176 - Key
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H08 0010
Coding: 0000120
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0020
Coding: 008800186D288505485ACE30
VCID: 79FC61F730B8018AFB-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H01 0010
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000120
VCID: 3A7EBEFB753ECA92B2-806E
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357
Component: Dynamische LWR H01 0050
Coding: 0000001
VCID: 77F867CF06AC17FA8D-8022
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 255
Reset counter: 45
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Reset counter: 45
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 45
Mileage: 1048568 km
Time Indication: 0
Address 56: Radio
Cannot be reached
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0000003
VCID: 78FA64F30BB2188284-802C
End-------------------------(Elapsed Time: 01:38)--------------------------
Here's my report
Cc:
www.Ross-Tech.com
Coding: 0000072
4 Faults Found:
Coding: 0053894
1 Fault Found:
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 45
Mileage: 189694 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:28
Freeze Frame:
Voltage: 8.80 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 189847 km
Time Indication: 0
Date: 2016.08.24
Time: 04:35:08
Freeze Frame:
Voltage: 13.50 V
(no units): 155.0
Temperature: 11.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 131
Mileage: 186864 km
Time Indication: 0
Date: 2014.11.20
Time: 00:03:54
Freeze Frame:
Temperature: 18.5°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 159070 km
Time Indication: 0
Date: 2013.09.21
Time: 00:52:47
Freeze Frame:
Temperature: 20.0°C
Coding: 16711696
Shop #: WSC 00000
5 Faults Found:
00906 - Horn (H1)
Coding: 0011602
Coding: 0000042
Coding: 0004403
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 48
Mileage: 187722 km
Time Indication: 0
Date: 2015.09.20
Time: 00:14:28
Freeze Frame:
Fault Priority: 1
Reset counter: 8
Mileage: 187722 km
Time Indication: 0
Date: 2015.09.20
Time: 00:14:28
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 8
Mileage: 187722 km
Time Indication: 0
Date: 2015.09.20
Time: 00:14:32
1 Fault Found:
01176 - Key
Coding: 0000120
1 Fault Found:
Cannot be reached
3 Faults Found:
Coding: 0000120
2 Faults Found:
Coding: 0000001
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 45
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 45
Mileage: 1048568 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 45
Mileage: 1048568 km
Time Indication: 0
Address 56: Radio
Cannot be reached
Coding: 0000003
