Help with thermostat
rhubarb4 May 2, 2009
  1. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    Hi all, I think my thermostat has broke as my engine temperature rises towards 120c when stationary. If i start to drive it comes back towards 90 even quicker if i put the heaters on max. What I'm trying to find out is it easy to get to as I have no clue where it is, and can I replace the thermostat myself or is it a dealer/garage only job. Thanks Chris:sos:
  2. Broken Byzan
    13,237
    465
    More likely waterpump failiure tbh. The plastic impeller breaks away from the metal shaft.
    However its a bit of a job to change depending on the engine
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Normal symptoms of the thermostat at fault is if your temp isn't getting up to 90. If its going past 90 and overheating like you say then it'll be the water pump like Mark said.
  4. rhubarb4
    1,754
    187
    Would that be why the Aircon suddenly stopped workin too
  5. Broken Byzan
    13,237
    465
    Arete electric fans still working when you switch the aircon on?
    Maybe a fuse gone then as the aircon and the temp are only connected as far as i can see by the fans
  6. rhubarb4
    1,754
    187
    Thanks, I will check that. Is the fuse in the side of the dash or under the bonnet and I hope it is that as I have had a cam belt change and had the plastic water pump changed for the metal one.
  7. Broken Byzan
    13,237
    465
    IIRC the fan fuse is in the car fuse box. For continuity, chech the ones on top of the battery anway, will take seconds.
