Help with the Cruise coding near Taunton
kndkris Mar 2, 2011
  1. kndkris
    kndkris New Member
    14
    Hey all, I pick up the parts for the cruise retrofit tomorrow, is there anyone around the Taunton area that can help with the coding? Wouldnt mind getting a scan done as well as i have only just purchased the car and would be interested as to what comes up.
    Ive got an A4 B7 3.2 Avant.
    Kris
  2. kndkris
    kndkris New Member
    14
    Fitted the stalk today, instead of buying new lower cowling i just used a dremel and half round file to extended the gap on the original, saves about 26 bucks f anyone is planning this in the future.
    Now thing is i need it coded in, is there anyone in the south west that can help out? willing to drive and provide beers/money.
  3. will89
    will89 Member
    357
    I'm looking to do this mod to my a4. On the vcds user map there is someone in taunton. I'm in gloucester but I'm often down there too. Have a look on the user map and you'll see who I mean and just pm them.
  4. Silverfoxxxx
    Silverfoxxxx New Member
    15
    Hi,
    I have cruise control fitted that does not work and I work in Taunton and also need a vcds scan to see what issues it brings up, can you let me know if you find someone in Taunton who can scan.
  5. kndkris
    kndkris New Member
    14
    Yeah will do, have already messaged dave_ph the local guy in Taunton so i'll let you know the response i get.
    The mod is real easy Will, just make sure you have a good torx screw driver set and i found a ratchet set with the arm that can kink very helpful. Give us a shout if you need a hand with it.
