help with springs??
bizzab7 Dec 20, 2012
  1. bizzab7
    bizzab7 Member
    102
    i have a 57 a4 1.9tdi s line and it failed an mot today due to a snapped rear coil spring.was told the price of a new spring was £70 plus £50 for fitting and i couldnt help but think its was a bit "harsh" for 1 spring.got me thinking about buying a set of h&r lowering springs for £175 and fit them myself.
    Was wondering if you guys think think you get a better ride with lowered springs(think i would have 40mm all round) or if the s line springs would be best?i know it would look better lowered as there is a gap between my arches and the wheels but wouldnt want to affect the ride comfort by lowering.
    Any info would be appreciated
  2. Joe_Murphy21187
    Joe_Murphy21187 Tiptronic
    1,021
    67
    SEARCH!
    Yes, the standard ride is pretty poor on s-line springs, aftermarket decent springs will improve ride quality, as well as give a better stance
  3. bizzab7
    bizzab7 Member
    102
    i have searched and i have my own opinion,but hearing from people who have have the worked done usually tends to help!
  4. pistonripper
    pistonripper Member
    34
    I can't say for H & R spring, but I have had Eibach springs in my Audi and they were brilliant, rode slightly lower, sharper handling. Although I hear that H & R are top quality springs...I know in the Mercedes forums they are all praises for them.
  5. bizzab7
    bizzab7 Member
    102
    thanks for the reply pistonripper,ended up just gettin a new s line spring fitted as i just wanted the mot out the way.did want it lowered but just wanted the mot out the way.hoping my new 19" rs4s willl fill the gap instead when i get tyres for them
  6. g00se
    g00se Active Member
    268
    26
    If you're fitting 19s i'd be even more inclined to lower it!
    I had Eibach's on my old R32, and i have H&R's on my S4.. ride and stance are very similar.. talk to Damian at DPM on here, he should be able to advise whats best for you.
    goose
  7. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,116
    2,570
    I second what g00se says. I got a set of Eibach lowering springs from Damian at DPM about three weeks ago. Top class information and service, and the car sits, handles and rides so much better than before.
  8. Chets
    Chets Member VCDS Map User
    31
    I fitted H&R springs on my s-line. They quote 40mm drop but as the s-line is already lower it dropped by about 20mm. I like the fact it still looks OEM but handling is definitely sharper and the MRS hasn't noticed any difference in ride comfort lol
  9. Joe_Murphy21187
    1,021
    67
    I've got H&Rs, 30mm (because they don't do any lower for the cab), and the ride and handling is improved from stock. Coming from s-line setup.
    Also went to 19"s at the same time, and I think the standard suspension with 19" would be pretty bad...
  10. Wrath
    Wrath Well-Known Member
    1,196
    41
    I now desperately need springs as had a rear passenger and could hear the wheels scraping :faint:
    I've never bought springs before so don't know what mm to get. Found these for £150, these okay or stock replacement. It's an S-Line with the 18" alloys:
    H&R Lowering Springs / Spring Kit for Audi - larkspeed.com
  11. bizzab7
    bizzab7 Member
    102
    think i will just get a set of lowering springs then as it seems everyone is agreeing its worth it.do u still have space after the drop and 19s jj?was thinking of lowering 40mm but dont want any rubbing
  12. davsa4
    davsa4 Member
    257
    19
    i have lowered mine on eibach sportsline 40/50 mm drop on my 56 plate s line and i am running 19 wheels with 45 offset and 15mm hubcentric spacers on rear 235/35x19 tyres ,the ride is much better than standard s line springs and i have had no issues at all with rubbing
  13. Wrath
    1,196
    41
    Torn between the eibach 40/50 and the H&R 35's. So you have no rubbing if you have passengers in the rear?
  14. Joe_Murphy21187
    1,021
    67
    As davsa4 said, you can get away with a 45mm drop with no rubbing issues. To be completely honest I'd like mine a bit lower, but I didn't think coilovers were necessary for my purposes and 30mm was the biggest drop I could find. Not sure if that's because mine is a cab or a 3.0tdi?? But it sits much better and rides a lot smoother than standard.
  15. davsa4
    davsa4 Member
    257
    19
    i
    have had 5 adults in my car with no rubbing issues
  16. DPM
    DPM Site Sponsor Site Sponsor
    4,962
    193
    I think you can't beat the stance of the Eibach Sportlines if you're just opting for springs.
    Damian @ DPM Performance
  17. bizzab7
    bizzab7 Member
    102
    davsa4 car looks spot on.alloys look excellent with the way your car sits.torn between eibach and h&r now
  18. ajax1976
    ajax1976 Well-Known Member
    1,272
    656
    A couple of pics of my car just after my H&R's were fitted, they have dropped a shade more now, first is with 19" wheels 2nd with 18's. No spacers as yet but will hopefully get them fitted soon. I test drove a car with Eibachs and don't think there's any difference at all between them and H&R's regarding comfort, both are much better than S line springs.
  19. Wrath
    1,196
    41
    I've gone for H&R's in the end, just got them today off DPM. Thought they were going to take another week to come :)
    Lucky really as I think one of the rear springs has gone as you can hear the rear tyre rubbing when doing 70 :(
  20. ajax1976
    1,272
    656
    Excellent, look forward to seeing pictures of them once fitted!!
  21. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    438
    H&R good Choice as the 3.0 TDI has a drop of 40 mil
  22. Wrath
    1,196
    41
    Only managed to install the new rear H&R -35mm springs owing to the faff we had with our non-standard spring compressors, there wasn't a lot of room behind the wheel! So this is my car with stock springs at the front. Obviously the new springs haven't had chance to settle yet. Just have in mind the before pictures were of my shot rear springs:
    After:
    [​IMG][​IMG]
  23. Wrath
    1,196
    41
    Hmmmm, now it seems every so often the fronts are rubbing. I assume the stronger springs at the back are doing that. Maybe I'll have to put them on sooner rather than later.
  24. Rheady
    Rheady Member
    71
    Are the shocks the same on the SE and the S-line.
  25. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Car looks spot on! What width are your wheels Dav?
    I'm looking to run a similar setup and just bought a pair of B5 spring perches so looking to fit some lowering springs at the same time as I hear it improves ride quality, handing and looks much nicer.
    My current setup is as follows:
    Wheels = 19" A6 Le Mans Edition 8.5j ET48
    Tyres = Vredestein Ultrac Vorti 235/35/R19 Y
    15mm spacers on rear (ET33) and in the process of putting 5mm spacers up front (ET43) as I am getting rubbing on full lock without them.
    As I have a 3.0 TDI Quattro, I am limited to the following options available on the DPM website:
    - AP 35mm @ £158.75
    - APEX 40mm @ £124.00
    - Eibach Pro 30mm @ £189.00
    - H&R 45mm @ £186.00
    - Vogtland Sport 30mm @ £190.00
    - Weitec F-Series by KW 35mm @ £217.00
    Quite a few options as you can see and most people seem to go for Eibach/H&R from what I've seen. I want something that will give me the most improved ride and also won't affect the life of the S-Line shocks (leaning towards Eibach 30mm in particular here). Baring in mind I will have B5 perches fitted up front (15-20mm lower) and it is on S-Line suspension (20mm lower than standard).
    Would you say the Eibach's would offer better ride quality than the H&R's as it is only a 30mm drop as opposed to 45mm?
    Thanks in advance, Azeem.
  26. spannah
    spannah Member
    238
    Alex how low did u go?
  27. davsa4
    davsa4 Member
    257
    19
    Azeem
    wheels are 8.5x19 with an offset of et 45 ,rears have 15mm spacers so in theory et30 ,springs are eibach sportsline 45mm front(25mm on s line) 35mm rear (15mm on s line) ,drives much better than standard s line springs did
    if you fit eibachs pros on yours it will only sit 10mm lower than standard as slines are 20mm lower than standard ,as for h7r i have never run them so cant comment but have heard good reports from people who have .
    dav
  28. ajax1976
    1,272
    656
    35mm H&Rs
  29. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Thanks, Dav.
    Any issues up front with that offset? I'm getting some rubbing on the arch liners on full lock with ET48. In the process of fitting some 5mm spacers (ET43) to try get rid of it.
  30. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,989
    754
    I'm looking at getting Eibach 40/50 springs, has anyone got a pic fitted with 18's on.
  31. davsa4
    davsa4 Member
    257
    19
    no issues at all mate
    dav
  32. ajax1976
    1,272
    656
    I test drove this car before I got mine. It has the 40/50 set up and 18" wheels but with B5 perches and 20mm spacers on the rear, it rubbed slightly on the rear due to the spacers.
  33. Macdoon
    1,989
    754
  34. spannah
    spannah Member
    238
    Thanks for getting back to me, it looks really low for 35mm. I take it in this shot the wheels are 19s?
  35. ajax1976
    1,272
    656
    Yip 19's. I'm not sure where H&R get the 35mm from, in every picture I've seen they look way lower and similar height to the 40/50 Eibachs.
  36. Wrath
    1,196
    41
    I looked at many pictures of the Eibachs vs the H&R and they are very similar. I have still yet to put the front springs on but the rear is nice and low with no rubbing. They are better than the stock and provide less harshness over bumps.
  37. spannah
    spannah Member
    238
    Yeh that stance looks much lower than 35mm looks more like a 50mm drop all round. I love them wheels but i am stuck between these wheels and the S4 ones.
    If i get 19s do i need to get spacers for the rears? What ones do i go for, and will i get any rubbing on a full car?
  38. spannah
    spannah Member
    238
    I dont have an S-Line but i have this exact model in black and i love the stance on the below;
    STUIWHITE's car
    I want these wheels in 19s
  39. V6 Quatt
    1,248
    438
    I would go for H&R 45mil drop had them fitted recentley along with RS4 ARB to my Quattro 3.0 TDI saloon. The car sits just right and they will settle and drop a little bit more i'm told. There is about 1.5 finger gap all around on 18's 19's going on soon.
    1. Ride comfort much improved,
    2. First thing I noticed, the ride less crashy smoother over bumps
    3. Car seems more leveled out and sterdy
    4. Stance is better
    Would recommend
    Hope this helps.
