help with reading my ecu with vag-com
John Spooner Mar 28, 2012
  1. John Spooner
    John Spooner Member
    124
    im after a remap and iv installed vag-com so was wondering if there was any way i could tell if the ecu is remap-able using vag com? if there is could anyone tell me how i could find out please, thanks
  2. <tuffty/>
    21,899
    4,206
    VCDS will tell you the ECU number when you go to the engine module.... that will enable the numerous tuners that have already sorta answered your question to confirm for sure..
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    you can usually check by the level of boost that is been requested too,, block 115..
  4. John Spooner
    John Spooner Member
    124
    apparently my a3 1.8t with the highest mass air flow readin at 110.14 in 3rd gear near 6000 rpm is 137.6 bhp:crying: not happy!!
  5. John Spooner
    John Spooner Member
    124
    block 115?? for the 3 i used 003,005,011 is that right or have i done it totally wrong?
  6. R-Tech-Nick
    R-Tech-Nick Active Member
    150
    51
    just log blocks 025 and come back to me with the reading and ecu number an i will tell you if its mapped or not.
    You dont have blocks 115 on your ecu.
  7. John Spooner
    John Spooner Member
    124
    i know its not remapped im just trying to figure out a way if i can read the ecu to see if i cam remap it through OBD2 or chip it
  8. John Spooner
    John Spooner Member
    124
    also would i have to red line it through 3rd gear like it did with the bhp output mas air flow reading??? is 137.6 about right for 155k 1.8t?
  9. R-Tech-Nick
    150
    51
    LOL I read the post wrong.. MYFUP.
  10. John Spooner
    John Spooner Member
    124
    lol still do you think 137.6 is a decent output for a high mileage 1.8t? or is that figure not going to be 100% from vagcom?
  11. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    137.6/0.8=172 bhp (rule of thumb)
  12. John Spooner
    John Spooner Member
    124
    no i got 110.14
  13. Alex C
    3,297
    373
    ah sorry, your air flow was 110 g/s. ok, got mixed up with the numbers. Yours is a 150 bhp model is it?
  14. John Spooner
    John Spooner Member
    124
    yea its ment to be or 148 bhp according to wikipedia, the figures from vagcom say 110.14 at 5760 rpm in 3rd gear! maybe il try it again and then a 4th gear run to compare the difference but then again it has 155k on the clock, iv heard these engines dont really lose power tho?
