Help with part Nos for brakes (2.0 TDI)
Stepho Feb 23, 2010
  1. Stepho
    Stepho Member
    444
    Can anyone help with following Part No's for an A4 2.0 S-line Avant:
    Front Discs and Pads.
    Rear Discs and Pads.
    Any help in sourcing good quality replacement parts also welcomed.
    Thanks in advance
  2. harmless
    harmless Member
    79
    if you want good quality pads then look at EBC redstuff break pads there worth every penny and stop amazingly just upgraded mine and cant fault them!
  3. Stepho
    Stepho Member
    444
    Where did you get them and do you know the part No's?
  4. matho
    matho New Member
  5. Stepho
    Stepho Member
    444
    Can Anyone confirm these Part Nos for the front Discs?
    4B0 615 301 C 312mm vented
  6. TorqueTerrorist
    TorqueTerrorist www.sprayplan.co.uk
    485
    94
    The Red stuff are superb! They are designed for heavier cars running 200+bhp so are perfect! I found them to work better from cold than OEM and get better and better the harder you use them! Fit them and you'll be braking from 130mph 1 metre before a roundabout! Lol.....well maybe a slight exageration but they are good with drilled and groved discs!
  7. Stepho
    Stepho Member
    444
    Anyone know or can advise where to find the OEM part Nos for the following components:
    Front Discs
    Front Pads
    Rear Discs
    Rear Pads
    Once I find the price for the OEM parts I can then compare the likes of 'Redstuff' aginst it.
    Thanks to all wh have posted the comments have been taken on board.
  8. jwhat
    jwhat Member VCDS Map User
    541
    if you pm pjmspeedy on here with your vin i'm sure he can give you a price or any dealer should help you either.
  9. harmless
    harmless Member
    79
    EBC Redstuff Brake Pads (Front) DP31483C £79.27
    EBC Redstuff Brake Pads (Rear) DP3680C £41.03
    EBC Greenstuff Brake Pads (Front) DP21483 £66.63
    EBC Greenstuff Brake Pads (Rear) DP2680 £35.57
    EBC Turbo Grooved Discs (Front) GD602 £162.35
    (Discs diameter 288mm)
    EBC Turbo Grooved Discs (Rear) GD1203 £116.50
    you will need to double check the discs but i believ they are correct
    The EBC Redstuff brake pads are an upgrade to your standard brakes and will give you much better braking performance. They replace your current ones without the use of any specialist tools. The EBC Greenstuuff brake pads are suitable for vehicle under 170bhp which are a softer brake compound and release less brake dust than the EBC Redstuff brake pads.
    i would recommend the redstuff pads to anyone cant belive how quickly they stop, i put mine on the standard discs and there amazing! my audi is at 210bph hence using redstuff but the overall improvement id use them on a standard audi no questions asked well worth the money
  10. TorqueTerrorist
    485
    94
    Best mod i made, even more so then the remap!
  11. harmless
    harmless Member
    79
    TorqueTerrorist - totally have to agree. altho i didnt put the groved discs on budget reasons but performace wise there amazing, feels like your eyes are getting sucked out when u stamp hard on them..:jump: one thing ive always said about my car was the brakes are totally sh** but now there amazing! wouldnt have thought different pads would have made such a difference :w00t:
  12. TorqueTerrorist
    485
    94
    To anyone reading this who has yet to experience these pads, it really is true! It rips your face off!!
  13. Stepho
    Stepho Member
    444
    Where is the best place to buy EBC stuff?
    Lookin for good Prices as its a full kit
