help with new turbo!
dappadan786 Feb 5, 2008
  1. dappadan786
    dappadan786 Member
    457
    hi guys, its been a while ive finally got the car back on the road!
    ive got the hybrid K04 fitted it feels sluggish and when i put my foot down car seems to slow down and shake!
    ive just bought an original VagCom lead, what should i be looking for? never done this before so looking for abit of help.!
    thanks.
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,768
    31
    Well the first thing to do is check for fault codes.
    Think the B5 code is '8D'. Run the 'Auto Scan' feature (do not click 'include airbags'). This will check for all fault codes.
    If that comes back clean, you want to go to 'Engine', then go into 'Measure Blocks'. Probably best searching the Vag-com forum for the best blocks for you to check on your car.
  3. Markey
    Markey Active Member
    2,175
    Sounds like it is in limp mode sort of or there is a boost leak maybe ?
  4. dappadan786
    dappadan786 Member
    457
    thanks lads! ill check it as soon as i get home from work.
  5. Markey
    2,175
    I remember when i had the other 1.8t with hybrid, i put on the N75j and it killed it would not go aboe 70mph with foot to the floor, not very quick off the line things like that, it kept hitting limp mode.
  6. dappadan786
    dappadan786 Member
    457
    heres the first a log from vag com. nothing serious that i can see apart from the red writing ive highlighted! ive done a throttle body alignment. any ideas? ive been told i need to measure the blocks? any ideas on how to do that?
    Thursday,07,February,2008,10:01:10:41956
    VAG-COM Version: Release 704.1
    Data version: 20071016
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Mileage: 127160km/79013miles
    Address 01: Engine Labels: 8D0-907-557-AEB.LBL
    Part No: 8D0 907 557
    Component: 1,8l R4/5VT MOTR HS D05
    Coding: 04001
    Shop #: WSC 00000
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 4D0-907-379.LBL
    Part No: 4D0 907 379 D
    Component: ABS BOSCH 5 7402
    Address 08: Auto HVAC Labels: None
    Part No: 8D0 820 043 H
    Component: A4-KLIMAVOLLAUTOMAT_D65
    Coding: 00041
    Shop #: WSC 06435
    1 Fault Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-00 - Open or Short to Plus
    Address 15: Airbags Labels: 8A0-959-655.LBL
    Part No: 8A0 959 655 B
    Component: Airbag V AUDI D00
    Coding: 00766
    Shop #: WSC 06334
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 8D0-919-0xx-17.LBL
    Part No: 8D0 919 035 M
    Component: B5-KOMBIINSTRUMENT__D10
    Coding: 00442
    Shop #: WSC 00751
    Address 25: Immobilizer Labels: None
    Part No: 4A0 953 234
    Component: IMMO AUZ9Z0T2715661 D77
    Coding: 00000
    Shop #: WSC 00000
    End --------------------------------------------------------------------------------------------------
  7. Blue_Thunder
    1,768
    31
    I mihgt be wrong here, but I think the HVAC is just something to do with the central locking.
    To measure the blocks, go into the 'Engine' module and click on 'Measure Blocks'. This will give you the option to look at (and log) up to three seperate blocks.
    The more blocks you choose, the slower the update intervals, so if you're wanting to do a max MAF reading, you're best off just logging against Block 003 on it's own.
    The blocks I measure on my S4 are:
    Block 001 - Lambda intervals
    Block 003 - MAF readings
    Block 032 - Check fuel trim (ie: how much the fuelling is having to be altered due to incorrect a/f mixture)
    Block 115 - Specified/Actual Boost readings (large gaps between these values indicate a boost leak)
    I'd recommend you check block 32 at idle first. Any values of more than a few % show a fuelling problem.
    Then Log 115 at WOT in 3rd gear. This will highlight any boost leaks.
    Then Log 003 at WOT in 3rd gear to see what your peak MAF reading reads. Your tuner should know what sort of MAF values you should be reaching with your map.
  8. dappadan786
    dappadan786 Member
    457
    Thanks Blue Thunder, thats helped me out alot!! im going to try that and see what happens. i suspect a boost leak or a bad MAF sensor.
    cheers mate.
