help with my conversion problems.
bobo139 Dec 5, 2012
  1. bobo139
    bobo139 New Member
    ok guys here they are.
    1,transponders are different.
    2,need to wire dbw or not.
    3,need to rewire dials.
    ok the plan was to put a 1.9 tdi 110 from a 1999 a4 avant into my 1.8 adr 1997 a4 avant.
    engine,fuel tank,lines,plumbing and everything is done other than whats above.
    now starting at no 1 the transponder(if thats what its called) on the back of the ignition barrel is different, 1997 has a long tapered bit that slots into the back of the barrel,1999 has a thin tapered part that does not reach the innards of the 1997 barrel.
    do i need to change the actual barrel cylinder too.
    no2 1997 had a cable throttle,1999 has dbw throttle.is my 1997 pre wired for dbw whereass they have hidden the plug.or do i have too wire this in.
    no3 the two plugs on the back of each dials are different to each other is this a matter of popping the pins and relocating to facelift plugs or is there more too it.
    any help atall guys and girls is much appreciated.
    also another downer to my day was that i found a hidden 1.9 tdi quattro sport 1997 that has been laying for a year and a half and the guy would not sell it.i was so so sad.lol.
  2. aragorn
    18,485
    855
    You will have to change the ENTIRE wiring harness to make this work properly.
    no point farting around trying to patch bits in here and there when so much is different.
  3. tonya4
    tonya4 TDi Powerrrr
    408
    as kev says
    tony
  4. bobo139
    bobo139 New Member
    will the 1999 loom fit my 1997 dash such as switches having the same plugs. reason being as i didnt want the facelift dash and ripped some of it out,aka broke some of it.lol
  5. murran
    murran Well-Known Member
    1,545
    39
    sorry for not helping but, never convert a car to one you can just go out and buy!
  6. aragorn
    18,485
    855
    He didnt even need to buy it, he already had the complete car lol.
    bobo: if the interior in the 99 looks different (facelift) then you'll need to transfer over the dash cluster, AC panel, switches etc.
  7. murran
    1,545
    39
    i cant imagine spending (read wasting) the shear amount of time/effort it would take to do what your doing.
    im presuming there was a reason why you dont just fix/use the 99 1.9 tdi and get rid of the wheezing "adr" 20v one?
    id break both cars and just go out buy the one you want when youve accumulated the cash!
  8. CraigG
    CraigG Member
    190
    not to mention the hike in insurance costs for running a modified car over a standard one...
