Help with limp mode problem
Chris-gsxr Jul 26, 2013
  1. Chris-gsxr
    Chris-gsxr Member
    57
    Cars in limp mode with the fault but the garage I'm using can't find the problem.
    Anyone have any suggestions?
    The code is 00665
    Turbo has been off for inspection. It was clean and in good order
    Dpf cleaned out. Still going in limp mode
    Sorry to re post. Not sure what section was best to post this in
    Hope someone can help :(
    Sent from my iPhone using Tapatalk 2
  2. Chris-gsxr
    Chris-gsxr Member
    57
    Bump. Anyone?
  3. audi-a6
    audi-a6 Active Member
    656
    72
    take it you have checked all your pipes for leaks? Is your "dv" okay? N75 valve and n249 valve okay?
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Are they using a generic fault code reader as using something like vcds will give a description of the fault too
    Nothing comes up on ross tech wiki
  5. audi-a6
    656
    72
    this might be of some use
    16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
    Possible Symptoms
    Reduced Power Output
    Limp Mode
    Possible Causes
    Hoses/Pipes incorrect connected, disconnected or leaking
    Charger Pressure Control defective
    Turbocharger faulty
    Diverter Valve faulty
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check / Clean / Replace Charge Pressure Control
    Check Turbocharger
    Check Diverter Valve
    Special Notes
    When found in 2.0l TFSI: Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer). RoW vehicles see: TPI 2016331 for details.
    NAR vehicles see: TSB 01-07-70 or 2013392 for details.
  6. Chris-gsxr
    Chris-gsxr Member
    57
    Cheers for that, ill pass the info on to see if anything has been overlooked
