Help with Kufatec heated seat wiring looms.
chris.vincent3 Mar 1, 2014
  1. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Hi, I have S3 seats in my A3 Sport and wish to wire in the heated seats, found this wiring loom on Kufatec's website, my seats are also electric as they have the circular button on the side with a 4 way switch. So, I assume the loom that I order is the adjustment variation of the heated seat loom? what's "lordose"?
    Seat Heating - Harness - Audi A3 8P & 8P Sport-34045-3
  2. Sayam
    Sayam Well-Known Member VCDS Map User
    2,712
    636
    Have the seats got elements installed already?
  3. chris.vincent3
    604
    34
    Yeah, they're the S3 seats.
  4. Sayam
    2,712
    636
    Sorry I didn't realise all S3 seats were heated...
    The 4-way switch you're talking about sounds like the lumbar support, is the rest of it electronically adjusting too?
  5. chris.vincent3
    604
    34
    I kind of am assuming they are, probably should check to make sure.
    I have no idea mate, the only thing my old seats had where the airbags, so everything else doesn't work. I'm going to assume they aren't as I have the lever under the seat to slide forwards/backwards.
  6. Sayam
    2,712
    636
    To me it sounds like the seats are manually adjusting but they have the lumbar support which is electronic.
    Also best to check if the seats have the elements in before buying looms etc
    PM Nigel (NHN) he's done loads of work on my car and is really good at what he does. He will be able to quote you to sort everything out assuming you have the elements....
  7. chris.vincent3
    604
    34
    So the lumber adjustment would be the "lordose"? Yeah, I'm doing some work on the car today so will check then. Just a case of looking under the seat to find wire coming from the cushion? I've got the wiring diagram so I'll see if the colour wire is in the female plug.
    I've spoke to NHN before, think he was too far from me, it's something that I can do myself anyway.
  8. chris.vincent3
    604
    34
    Went for the heated seat and lordose loom in the end, the seats do have the heated element in them and the 4 way switch is the lumber support? Which is I assume "lordose".
  9. Phatboyruss1
    Phatboyruss1 Member
    75
    Yeah, lordose is the lumbar support. Need my seats sorted as well... Waiting on a response from NHN.... hes in high demand so must be good!! :)
  10. chris.vincent3
    604
    34
    I'll let you know how it goes with these looms, may be simple enough to do it yourself :)
  11. chris.vincent3
    604
    34
    Got my looms today, no fitting instructions and to download them off their site I need a customer and invoice number? Haven't got one on my invoice nor in any of my emails?
  12. hades-
    9,481
    646
    email and ask for it
    they will sort it
    but there easy to fit
  13. Phatboyruss1
    Phatboyruss1 Member
    75
    Have a look on the Richter Motorsport site (I don't know of you go them from there) there should be a download there
