Help with front wishbones
imported_Jamesh Oct 6, 2005
  1. imported_Jamesh
    imported_Jamesh Guest
    Hi,
    I have an early S3 and the front wishbone bushes are knackered, I plan to replace the whole arm, can anyone tell me if the A3 uses the same front wishbone.
    James
  2. jojo
    28,846
    3,509
    No, S3 wishbones have slots on the end for camber adjustments which the A3 items don't have. Go for late spec front wishbones, they are slightly different shape and weigh a little bit less according to Ed at AmD when I had mine replaced, plus you have to get your wheel allignment sorted again, but made a slight improvement in handling (maybe the old one's were too knackered?). /ubbthreads/images/graemlins/beerchug.gif
  3. imported_Jamesh
    Cheers Jojo for the quick response does anybody know of another place to try and get these wishbones.
    I've tried VAGPARTS they want £68 + vat, Europarts want £82 + vat and GSF say they dont sell wishbones for the S3.
    Also has anybody tried replacing the bushes in the old arm, I know i dont stand a chance with the original bushes, but what about poly bushes such as Powerflex.
    Any help on the above would be great
    James
  4. paulbinks
    paulbinks Member
    56
    Yo
    Front bushes on an S3 are easy enough to replace with powerflex if you have two people and a vice,just follow the instructions for removal on there web site, the powerflex bushes make a massive difference to steering feel and the way the car feels and corners especially if an R32 rear arb is fitted.
    Cheers "Bingo"
  5. RichA3Turbo
    5,089
    For ease, just buy new ones. For improvements fit powerflex bushes. I can do those for you @ £67.80+vat/del (4 bushes, 2 per side)
    Rich
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    how much harsher is the ride with powerflex bushes. I just went for replacement arms as i felt the ride would suffer with the **** roads where I live.
  7. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    Really not that different. I'm using the ECS bushes which are firmer than the powerfled bushes and they are fine.
    RIch
  8. paulbinks
    paulbinks Member
    56
    The powerflex bushes are no harsher than standard bushes but the trade off in terms of increased feel and control where it matters made it a no brainer plus i got the whole front end kit free of charge including arb and steering rack mounts,only took a few hours to do and removing the old bushes was the hardest part.
    Cheers "Bingo"
  9. RichA3Turbo
    5,089
    For removing the old bushes, i drilled out the majority of the old bush, and then used a blow torch and a chisel to remove the rest. Basically just burnt it out and scraped the rest with chisel.
    Rich
