Help with fitting vent gauge
PaulJC84 May 10, 2005
  1. PaulJC84
    PaulJC84 Owner
    2,911
    17
    Hi all i have a gauge to fit in eiither my centre vent or drivers side one.
    I dont mind which one it goes in just whichever is easier.
    I was wondering how everyone who has done this has fed the boost hose through from the bulkhead to inside the vent?
    I had a look yesterday evening and it is looking petty tricky.
    Cheers,
    Paul.
  2. hop2407
    hop2407 Active Member
    1,408
    Would love to help mate - but this kind of thing is out of my league...... I would normally have a go at most things (DIY), but the car, I tend to leave it to the experts.... sorry Soupie...
  3. madkebab
    madkebab Member
    421
    I used an existing grommet in the bulkhead which is slightly off centre towards the nearside. Will take a pic when I get a chance. If you wanted to have the gauge on the drivers side rather than central you could use the grommet in the front of the ECU cover and then through the bulkhead. I used this grommet to run my power cable for my amp.
  4. PaulJC84
    PaulJC84 Owner
    2,911
    17
    Then how do u get the hose from the bulkhead into the back of the vent?
  5. Markey
    Markey Active Member
    2,175
    I took out my whole centre console so i could easily just move the wire about as mine does not use a hose but a set of sensors as it is micro prosessor based.
  6. Austineer
    Austineer King of cabs ;) Audi A3 Audi Cabriolet Owner Group TDi
    161
    Paul,
    I actually did a little write up about a year ago on how to fit a boost gauge in the center air vent. Try finding it and it will give you a good idea how to go about fitting the gauge. Unfortunately no pics but its quite straight forward.
  7. PaulJC84
    PaulJC84 Owner
    2,911
    17
    Ok cool here is a link for anyone else who wants a peek
    APR Boost Gauge
    What is the airflow guard?
  8. dummi
    dummi smoking a6
    1,210
    nice one, i was curious about this myself, on AWE site it says it can be put in the vent and vent still operate,
    have you done that or put a blank panel in?
  9. Austineer
    161
    Dummi,
    The vent will operate, however to put the gauge in the middle vent you will get the following:-
    a) air constantly comming out of the vent to the right of it
    b) none out of the centre one with boost gauge (obviously)
    c) full control to the one on the left
    N.B. I am refering to the central vent unit which contains 3 individual vents in the center of the dash if anyone else is wondering.
    The three vents in the centre of the dash are only controlled by two flapper plates on the rear of the unit itself. When you fit the boost gauge in the middle vent of the three you have to remove the flapper (molded plastic) plate from the rear of the vent assembly which allows air into the centre and right hand vent. (Dont worry when you have a play you will see exactly what I mean). With the left hand vent left totaly untouched and fully operational.
    Happy playing guys. I must say that if you are thinking of playing with different turbo's & N75's you have to have one or you will end up doing some damage. A great safety feature for £180, a good diagnostic tool and it actually looks great particularily in the night as the gauge is the same red light as the rest of my dash.
  10. dummi
    dummi smoking a6
    1,210
    kool i'm going to have a fiddle this weekend
  11. PaulJC84
    PaulJC84 Owner
    2,911
    17
    dummi, have a fiddle what about the vent!! /ubbthreads/images/graemlins/cry.gif
    Just kidding let us know how you get on!!
  12. dummi
    dummi smoking a6
    1,210
    oh yeah the vent /ubbthreads/images/graemlins/lol.gif
  13. dummi
    dummi smoking a6
    1,210
    just picked up some vents from the scrappy will cut 'em ad see how theylook with the guage
  14. dummi
    dummi smoking a6
    1,210
    how have you mounted it?
    just wondering generally would there be a problem with the heat from the vent effecting the guage readings, especially a mechanical, thinking of getting some rubber boots for mine.
  15. dummi
    dummi smoking a6
    1,210
    kool looks good
