Help with finding some how to guides
mattyboy199 Jan 28, 2013
  1. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    Guys,
    I'm struggling to find some S3 how to guides for the following
    Rear shock change
    Fuel filter change
    I'm hoping to change springs, shocks, thermostat fuel filter at the weekend, i've done a search but it hasnt returned much.
    Any help would be spot on !
    Regards
    Matt
  2. epox
    epox Active Member
    772
    74
    VWVortex.com - Rear shock install - DIY with pics
    take its the same for the s3
    Have a look at this guide to give you an idea of whats involved...
    Noah's MkIV VW H&R Coilover Installation HOWTO
    The rears are different on the quattro (A3 or S3) to the FWD A3/Golf but principle is similar...
    Only specialist tools required for suspension are spring compressors for the front and the little spreading tool to open the front hub to remove the strut (see the above guide for details)
    Rear springs should be easy enough to remove and replace without compressing them, just need to undo the lower damper bolt (also attaches the rear ARB drop link) and push the suspension arm down enough to wiggle the spring out..
    Word of warning though.... make sure you undo the little arm attached to headlight height sensor which is connected to the passenger side upper tie bar on the rear as it WILL break if you do not before attempting to remove the rear spring...
    Depending on how low you go with the replacement springs, you may well need to get adjustable rear tie bars to dial the camber back in again.... there are a number of threads about this and look in the performance bit of the stickies at the top of this forum for more info too...
    The Audi TT Forum :: View topic - HOW TO CHANGE A THERMOSTAT ON A 225TT
    may give you some info
    cheers mark
  3. mattyboy199
    1,885
    Thanks for the info Mark just what i need !
