Help with Fault Code
madkebab Jan 4, 2006
  1. madkebab
    madkebab Member
    421
    Have got a problem with my 1996 A4. The car will start but then cuts out with the immobilser light flashing on the dash. Hooked up VAG-COM and got the following fault from the immobiliser module. Anyone able to shed some light on this before I resort to the stealers?
    01177 - Engine Control Unit
    65-10 - unauthorized - Intermittent
  2. danej
    danej Member
    49
    common prob! try disconnecting your battery for a bit
    sometimes it works
  3. madvw
    madvw Active Member
    2,489
    duff key chip?
    intermittent ignition barrel reader?
  4. HTC
    HTC Active Member
    3,428
    9
    Failing key reader on the steerig column?
