Help with erroe codes on telephone/bluetooth..please with fault log
welshwoody Jun 8, 2011
  1. welshwoody
    welshwoody Member VCDS Map User
    438
    10
    Hi guys, yet another plea for help from me here so here goes....
    I recently bought a brand new genuine OEM audi bluetooth unit, installed it and had it all coded up but it still wont connect, its there but says the phone may not be connected properly. If I disconnect the bluetooth box it tells me that its not installed9or a similar message).
    After being out by the car for a few hours looking at things my neighbour came out to see if he could lend a hand as his son has an A3 that he`s always "podging around with". He said his son has the kit to code the car and asked if I wanted to use it, that was yesterday so today I get a knock on the door and its Craig, the guys son.
    He scans my car and has a quick look but said it seems to be coded properly. Ive got a copy of the scan that he emailed me soo Ill copy and paste it in, theres a few errors, all phone\radio related, does it look like the BT unit is screwed? everything else works fine but I want to get this working as I had it in y previous A3.
    Sorry for the ranting and lack of full stops, Ill put a few extra here to make up for it......
    Any advice is greatly appreciated.
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
    VIN: DELETED Mileage: 120090km/74620miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 021 TP HW: 03G 906 021 AN
    Component: R4 1,9L EDC 000SG 2595
    Revision: --H09--- Serial number: AUX7Z0H9FN60G6
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    VCID: 800B0433AA93
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 13422012092700FDC81304E4901D00813800
    VCID: 74E3D8E36E2B
    Address 08: Auto HVAC Labels: None
    Part No: 8P0 820 047 B
    Component: J255 Klima Man H07 0030
    Shop #: WSC 00000 000 00000
    VCID: 2F69178FC78D
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000008984701
    Coding: 11A82F81B0141380EF00001C0000000000084E1564010403002800000000
    Shop #: WSC 06314 000 08192
    VCID: 489B5C134223
    Part No: 8P2 955 119 F
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142383038303030374A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 499D59175929
    Driver's Airbag Crash Sensor:
    Serial number: 3572DRB400008059011A
    Passenger Side Airbag Crash Sensor:
    Serial number: 3582DRB400008058710G
    Driver's Rear Airbag Crash Sensor:
    Serial number: 35128RB4000044A0A249
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 35228RB4000044B38017
    Driver's Front Airbag Crash Sensor:
    Serial number: 35547RB40000464977FW
    Passenger's Front Airbag Crash Sensor:
    Serial number: 35647RB400004649750G
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002012
    VCID: 418D41376119
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
    Component: KOMBIINSTR. VDO H18 0830
    Revision: D0H18006 Serial number: 2249H006007530
    Coding: 0004428
    Shop #: WSC 00011 888 96745
    VCID: 397D29D709C9
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K0893003FA
    Coding: E9807F064006022103
    VCID: 356525E725D1
    1 Fault Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 120022 km
    Time Indication: 0
    Date: 2011.06.04
    Time: 12:08:28
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H18006 Serial number: AUX7Z0H9FN60G6
    VCID: 397D29D709C9
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
    Component: RNS-E HIGH EU H76 0650
    Revision: 05S Serial number: AUZBZ7J0907106
    Coding: 0205715
    VCID: 3D753DC71DE1
    2 Faults Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 119956 km
    Time Indication: 0
    Date: 2011.06.02
    Time: 13:43:06
    Freeze Frame:
    Mileage: 120020 km
    Count: 406
    Clock: 12:08
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 2
    Mileage: 119803 km
    Time Indication: 0
    Date: 2011.05.25
    Time: 12:07:36
    Freeze Frame:
    Mileage: 119800 km
    Count: 2505
    Clock: 12:07
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000692
    VCID: 43814B3F7B05
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 232 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5F069BFC6F
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002186D0985054C9FC637
    VCID: 43814B3F7B05
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000692
    VCID: 448348237E0B
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
