help with cruise retro fitting
cheech Mar 11, 2007
  1. cheech
    cheech Member
    62
    hi
    can anybody here help me ?
    new a4 owner excellant car ... but ( i Feel ) lacking cruise control !
    ive looked into pricing up cc kit but local audi stealers say may need new ECU ?
    they said you could tell with diagnostics ....
    so im going to order VAG COM hex-usb can from Gendan.co
    but dont really now much about where to start looking ?
    what in vag-com am i looking for ? to say if ECU is needed ?
    its a 2003 A4 v6 tdi Quattro Sport 180 ps
    ANY HELP MUCH APPRECIATED
    thx
    Cheech
  2. Les 51
    Les 51 A pint of Diesel please!
    687
    Thats interesting .... I own a 2002 A4 and am looking into Cruise control as well, but no one has told me that. I'll have to ask the person thats going to fit it next week. If I find out I'll let you know
  3. VTEC_Killer
    VTEC_Killer Member
    92
    What a load of BS from the stealers - all you need is a new stalk and someone to program it via vag-com!
    The parts will cost you about £150 - £180.
  4. chris_20
    chris_20 Member
    707
    interesting.....cheaper than what i woulda thought
  5. cheech
    cheech Member
    62
    so when i connect upto vag com what should i be lookin for ?
    parts via stafford audi on E*ay are cc kit £125 + lower cowling for £25
    he said that the car needs ecu situated under dash or wing on o/s
    and can only tell when connected upto Diagnostis machine ?
    ive ordered VAG-COM HEX-USB CAN so should be here Tues
    How do i activate cc in main ECU ?
    Thanx
    Cheech
  6. VTEC_Killer
    VTEC_Killer Member
    92
  7. b19rak
    b19rak Member
    46
    APS in Brackley did mine £230ish all in. Top blokes. Give them a call.
  8. Les 51
    687
    Right I have some more info for you, If your steering wheel isn't multi function you will need to change your steering column ecu! If you have a multi function wheel then you should be ok.
    I haven't so I need the Ecu
  9. arthurfuxake
    1,308
    BUT, some model years came out with the upgraded steering column ecu even though they didn't have multi-function steering wheels. My 2001 B6 A4 didn't, but my 2003 B6 A4 did have the upgraded steering column ecu and it hasn't got a multifunction steering wheel. It depends on how honest your dealer is. I used Links Audi for both my cruise retro-fits, and on my second one, they were honest and told me that they had found that my cars ecu was an upgraded one. I don't know the part numbers, is there any way you can get to yours to check it's part no?
  10. Les 51
    687
    You may be right arthurfuxake mine is a 2002 B6 and the guy who will fit it is an Audi guy who works for himself and is highly recommended and he told me mine wont have it. So maybe they put it in later?
  11. LandSpeed
    LandSpeed Member
    229
    how much is the steering column ECU?
  12. Les 51
    687
    the total cost of supplying the parts and carrying out the fitting and coding procedure will be in the region of £290 inclusive. The parts required are Control lever, ECU and lower steering coloum couling.
  13. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    That wasn't true when I retro-fitted cruise control to my 2004 B6 S4. The factory had fitted a "down market" version of the SCSM (steering column switch module) which wouldn't accept the coding for cruise control - so as well as the cruise switch and steering column trim I had to buy a new SCSM.
  14. cheech
    cheech Member
    62
    Thanx to all for replies :icon_thumright:
    due to all replies with helpfull hints links etc
    ive managed to work my new HEX CAN USB + vag com out (i think ... Lol )
    to get to conclusion that i have the Wheel Ecu that is not compatable with cruise :( .. (the one with part number ending F )
    meaning that new ecu is needed
    i also think that ive managed to work out my login for ecu ( not tried yet )
    so when i get parts which should be Tues am im on the job of fitting cc
    Parts will cost ( from Stealers )
    new SCM £ 103
    cc kit £ 114.89
    new bottom cowling £20.80
    all + VAT minus 12.5 % Trade Discount
    Thx again :respekt:
    Cheech
  15. cheech
    cheech Member
    62
    hi
    can anyone help me find
    VALID LOGIN CODES FOR ENGINE 1 + STEERING 16 ?
    i thought i had them but they dont work
    many thx
    Cheech
  16. timps
    timps Shakersville
    235
    This post on tyresmoke should help you coding
  17. cheech
    cheech Member
    62
    hi can any 1 help ?
    ive fitted cc today BUT CANNOT ENABLE IN ECU ?
    ive also managed to break main beam stalk !!!!!!!!!!!!!!! :(
    ( new stalk here 2morrow )
    the question is ive gone to
    engine1 then coding
    entered : 11463
    Do it
    BUT THIS IS NOT WORKING ?
    WHEN IVE DONE THE ABOVE I STILL CANNOT GET THE GREEN CRUISE LIGHT WHEN PUTTING IGNITION ON ?
    please help
    many tyhx
    Cheech
  18. timps
    timps Shakersville
    235
    The green cruise light only comes on above a certain speed IIRC 25mph I assume that is what you mean by putting the ignition on.
    Have you checked the clutch pedal switch ?
    There have been quite a number of cases where a faulty clutch pedal switch would not let the cruise control activate.
  19. cheech
    cheech Member
    62
    @ Timps
    was lookin into clutch switch
    on tyresmoke they were saying a blue clutch switch , mine is WHITE ?
    could this be prob ?
    how can i check clutch switch ?
    thx
    cheech
    ps
    HOW CAN I CHECK IF CC IS ENABLED IN ECU ?
    WHAT I MEANT BY GREEN LIGHT WAS I THOUGHT IT WOULD SHOW WHEN YOU PUT IGNITION ON ? ie with rest of ign lights ?
    thx again
  20. timps
    timps Shakersville
    235
    Yes the clutch switch could be the problem & Audi do have a habit of changing colours.
    You can check in vag com by pushing the clutch peddle and see if it alters the readings in the Measuring blocks.
    You should also see changes in code when moving the cruise control stalk in VAG com on the ecu also in the measuring blocks.
    The green light only comes on if you activate the cruise control above a certain speed (IIRC its 25 mph) below this speed and the light will not activate even on a fully functioning cruise control.
    measuring block information:
    066,0,Cruise Control System
    066,1,Vehicle Speed,(current)
    066,2,Switch Positions I
    ; 1xxx = Cruise Control System active
    ; x1xx = Clutch operated (always 1 with Automatic Transmission)
    ; xx1x = Brake operated (Brake Pedal Switch)
    ; xxx1 = Brake operated (Brake Light Switch)
    066,3,Vehicle Speed,(specified)
    066,4,Switch Positions II
  21. cheech
    cheech Member
    62
    sorry for being thick !!!!!!!!!
    you say in measuring blocks ?
    i take it you mean 01 engine , measuring blocks 08 then block 66 ?
    thx
    Cheech
  22. cheech
    cheech Member
    62
    :icon_thumright: UPDATE !!!!!!!!!!!
    CRUISE IS FULLY WORKING ..........
    THX TO ALL FOR YOUR HELP
    WHAT WAS THROWING ME WAS THAT EVERY OTHER MAKE OF CAR I HAVE DRIVEN WITH CRUISE CONTROL FITTED ALL SHOWED THE CRUISE LIGHT ON WHEN YOU TURNED THE IGNITION ON .........
    BUT NOT ON MY A4 QUATTRO SPORT !
    :icon_thumright:
    cheech
