Help with Coding i have a few things show up malfunction in VCDS
Yonner Aug 6, 2013
  1. Yonner
    Yonner Member
    155
    Hi guys , girls ,
    i run a full scan on my S3 tonight and it come up with a few malfunctions , it has somat to do with the Nav and radio and also says Tv tuner in there too? i do have 2 things on my window screen which i think are aerials, i hope some one can help me on this, any advice is appreciated :)
    ok here are the errors in vcds i am copying and pasting info:
    Address 37: Navigation Labels: None
    Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
    Component: RNS-E HIGH EU H75 0650
    Revision: 06S Serial number: AUZBZ7H0903812
    Coding: 0209757
    Shop #: WSC 00000 781 01234
    2 Faults Found
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 84111 km
    Time Indication: 0
    Date: 2013.08.06
    Time: 16:11:58
    02005 - Coding Pin
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 84111 km
    Time Indication: 0
    Date: 2013.08.06
    Time: 16:12:08
    next one is:
    Address 56: Radio Labels: None
    Coding: 0209757
    2 Faults Found
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 84111 km
    Time Indication: 0
    Date: 2013.08.06
    Time: 16:11:58
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 84111 km
    Time Indication: 0
    Date: 2013.08.06
    Time: 16:12:08
    and last one:
    Address 57: TV Tuner
    Cannot be reached
    thanks for any help!:rockwoot:
  2. NHN
    29,351
    1,720
  3. Yonner
    Yonner Member
    155
    i will take a look at the link , thanks for your quick reply NHN :)
  4. Yonner
    Yonner Member
    155
  5. Ash187
    7,495
    744
    Go into the gateway (19 iirc) coding and select the rnse, deselect the tv tuner.... Also check the coding for the rnse.... Sounds like someone retrofitted the rnse but didn't code it properly. I see this a lot and I'm sure Nigel does too.
  6. Yonner
    Yonner Member
    155
    Ahh ok I will have a look in the gateway and see what's about , the nav is actually working in the car so I don't know why it's saying malfunction ?
    Cheers ash
  7. Ash187
    7,495
    744
    Yes it will work since its plugged into the can network but it doesn't look like its coded correctly... It's not a big issue but it would be good to code it all the right way
  8. Yonner
    Yonner Member
    155
    I will get my laptop out now , just found this under steering wheel while fitting footwell bulbs
  9. Yonner
    Yonner Member
    155
    Anyone know how to get this working ?
  10. Yonner
    Yonner Member
    155
    just checked my spec with a pr decoder mate and it says my car come with nav , look here are all my PR codes
    PRCode: 0GG = Emission standard EU4
    PRCode: 0YC = Weight range 3 installation control only no requirement forecast
    PRCode: 1AT = Electronic stabilization program (ESP)
    PRCode: 1KW = Disc brakes rear
    PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
    PRCode: 1SA = Without additional engine guard
    PRCode: 1ZK = Disc brakes front
    PRCode: 2PF = Leather trimmed multi-function sports steering wheel
    PRCode: 3FE = Electric slide/tilt sunroof with sun screen/sunblind
    PRCode: 3L3 = Manual height adjustment for front seats
    PRCode: 3NU = Rear seat bench unsplit backrest split folding with center armrest
    PRCode: 3Y6 = Sun screen for rear window
    PRCode: 4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
    PRCode: 4K2 = Radio remote controlled central locking SZV
    PRCode: 4KC = Side and rear windows in heat-insulatingglass
    PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
    PRCode: 4UE = Air bag for driver and front seat passenger
    PRCode: 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
    PRCode: 5RU = Right exterior mirror: convex (large viewing field)
    PRCode: 5SJ = Left exterior mirror: convex
    PRCode: 5TG = Decorative aluminum inserts dulling
    PRCode: 6C0 = Curtain air bag
    PRCode: 6XK = Exterior mirrors: automatically dimming electrically foldable/adjustable/heated
    PRCode: 7A2 = CD changer
    PRCode: 7K6 = Flat tire indicator
    PRCode: 7Q2 = Navigation system with color screen
    PRCode: 7X1 = Park distance control
    PRCode: 8BP = Bi-functional headlight with gas discharge lamp
    PRCode: 8GU = Alternator 140 A
    PRCode: 8Q5 = Headlight-range adjustment automatic/ dynamic with dynamic bending light (AFS 1)
    PRCode: 8Z5 = Not hot country
    PRCode: 9Q2 = Multi-function display/on-board computerwith check control
    PRCode: CC1 = Alloy wheels 7.5J x 18
    PRCode: D3Q = 4-cyl. gasoline engine 2.0 l/195 kW 16V turbo FSI homogeneous Base engine is TA2
    PRCode: EA0 = Without subsequent warranty
    PRCode: FA0 = Control of standard production
    PRCode: G12 = Front shock absorption
    PRCode: J0L = Battery 340 A (70 Ah)
    PRCode: L26 = Suspension range 26 installation control only no requirement forecast
    PRCode: QG1 = Service interval prolongation
    PRCode: TA2 = 4-cylinder gasoline engine 2.0 L unit 06F.D
    PRCode: U1B = Instrument insert with mph speedometer clock tachometer and trip odometer
    PRCode: UB5 = Rear shock absorption for sports design
    PRCode: UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
    PRCode: X2B = National sales program Great Britain
  11. Yonner
    Yonner Member
    155
    Any help on this why the tuner is not working ? I noticed the antenna on the inside of the car have red led lights on them but are not lit up ? The actual DVB alpine tuner does have power because the led is lit up on the unit ?
