Help with codes for B6 A4 1.8T
am8631 Jul 22, 2009
  1. am8631
    am8631 New Member
    my friends A4 1.8t (b6) is having a few probs. It has cut out on him a couple of times and the EPC light is on.
    I ran the codes and got the following:
    Tuesday,21,July,2009,17:29:10:31547
    VCDS Version: Release 805.4
    Address 01: Engine
    Control Module Part Number: 8E0 906 018 B
    Component and/or Version: 1.8L R4/5VT 0004
    Software Coding: 11501
    Work Shop Code: WSC 63351
    Additional Info: WAUZZZ8EZ1A054559 AUZ6Z0A0082978
    7 Faults Found:
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 35-10 - - - Intermittent
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 35-10 - - - Intermittent
    17947 - Clutch Pedal Switch (F36): Implausible Signal
    P1539 - 35-00 - -
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 35-00 - -
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
    P0106 - 35-10 - - - Intermittent
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 35-10 - - - Intermittent
    17658 - Fuel Level too Low
    P1250 - 35-00 - -
    I unplugged the MAF and the car ran fine - would you say that this is all pointing to the MAF being on its way out?
    any help is much appreciated!
    ta
    Andy Mac
  2. technics100
    technics100 Active Member
    850
    25
    Change the MAF first, get the Bosch part number and go direct to a bosch dealer, will be cheaper that way. The System too lean, could be a boost leak somewhere, but change the MAF clear the codes and take it from there..
  3. Marcos M
    Marcos M Member
    35
    Clear the codes and take it for a run before you do anything, check the codes again and see what you got.
    A few of those codes would indicate a crank sensor, this also brings on the epc light you mentioned.
    HTH.
  4. Marcos M
    Marcos M Member
    35
    Just looked at the codes a little closer, and if they all come back again after you clear them I'd say Your friend has a boost leak and a crank sensor on the way out, maybe a few other lesser issues to.
    I'm speaking from personal experience here but I'm no expert.
  5. am8631
    am8631 New Member
    He has had these codes before - i cleared them and now they have returned! I will have a look at the car tomorrow to see if i can track any of these probs down.
  6. Marcos M
    Marcos M Member
    35
    Well
    P0322 - 35-00 - -
    I would say these 2 codes along with the EPC light and cutting out are caused by the crank sensor on the way out, it can also cause the tacho to go erratic and give a really bad kangaroo.
    This one
    and possibly this one
    a vac leak
    Others well maybe bad sensors/switches. There does seem to be alot of codes, I'd be tempted to check the wiring looms especially near the turbo as it does get incredibly hot there, when I bought my car I had about 6 wires melted or partially melted all shorting to each other due to a previous owners bodge.
    Good luck
  7. Xmay4444
    Xmay4444 On Point!!
    258
    Some of those codes and what you are discribing are very similar to what i had on my 2001 1.8T.
    Cause?, split vacum hose.
