Help with car running like **** Audi S3 2001.
shaunf84 Feb 22, 2013
  1. shaunf84
    shaunf84 New Member
    20
    Hi all, I have an Audi s3 2001, and its running like ****. Car is juddering like mad.
    Ive ran Vag-Com and got:-
    Address 01: Engine
    Controller: 8N0 906 018 J
    Component: 1.8L R4/5VT 0003
    Coding: 10710
    Shop #: WSC 01236
    WAUZZZ8LZ11003532 AUZ7Z0A1839575
    8 Faults Found:
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-00 - -
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-10 - - - Intermittent
    16487 - Mass Air Flow Sensor (G70): Signal too High
    P0103 - 35-10 - - - Intermittent
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    17963 - Charge Pressure: Maximum Limit Exceeded
    P1555 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16686 - Cylinder 2 Misfire Detected
    P0302 - 35-00 - -
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-00 - -
    Readiness: 0000 0000
    Replaced the MAF Sensor cleared the faults, and re run vagcom to get:-
    P0103 - 35-10 - - - Intermittent.
    I've read various posts, saying log 003, 115, 118.
    A standard car should be 180 g/s and a mapped card 200 g/s
    [TABLE="width: 384"]
    [TR]
    [TD="width: 64"][/TD]
    [TD="width: 64"]Group A:[/TD]
    [TD="width: 64"]'003[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]Engine RPM[/TD]
    [TD]Air Mass Flow[/TD]
    [TD]Throttle Opening[/TD]
    [TD]Ign. Timing[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD]%[/TD]
    [TD] °BTDC[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]0[/TD]
    [TD="align: right"]920[/TD]
    [TD="align: right"]4.3[/TD]
    [TD="align: right"]4.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1.17[/TD]
    [TD="align: right"]880[/TD]
    [TD="align: right"]12.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]2.56[/TD]
    [TD="align: right"]3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3.77[/TD]
    [TD="align: right"]3.9[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]4.97[/TD]
    [TD="align: right"]960[/TD]
    [TD="align: right"]4.7[/TD]
    [TD="align: right"]23.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]6.29[/TD]
    [TD="align: right"]1240[/TD]
    [TD="align: right"]5.5[/TD]
    [TD="align: right"]26.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]7.69[/TD]
    [TD="align: right"]1440[/TD]
    [TD="align: right"]5.9[/TD]
    [TD="align: right"]30[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.99[/TD]
    [TD="align: right"]1760[/TD]
    [TD="align: right"]8.2[/TD]
    [TD="align: right"]31.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]10.32[/TD]
    [TD="align: right"]2200[/TD]
    [TD="align: right"]12.2[/TD]
    [TD="align: right"]32.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]11.52[/TD]
    [TD="align: right"]3400[/TD]
    [TD="align: right"]15.7[/TD]
    [TD="align: right"]36.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]12.73[/TD]
    [TD="align: right"]4000[/TD]
    [TD="align: right"]15.3[/TD]
    [TD="align: right"]38.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]13.93[/TD]
    [TD="align: right"]3520[/TD]
    [TD="align: right"]5.1[/TD]
    [TD="align: right"]3.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]15.23[/TD]
    [TD="align: right"]2.4[/TD]
    [TD="align: right"]21.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]16.54[/TD]
    [TD="align: right"]3.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]17.85[/TD]
    [TD="align: right"]840[/TD]
    [TD="align: right"]21[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]19.07[/TD]
    [TD="align: right"]3640[/TD]
    [TD="align: right"]100[/TD]
    [TD="align: right"]30.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]20.36[/TD]
    [TD="align: right"]2280[/TD]
    [TD="align: right"]2.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]21.58[/TD]
    [TD="align: right"]3960[/TD]
    [TD="align: right"]14.5[/TD]
    [TD="align: right"]11.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]23.08[/TD]
    [TD="align: right"]33.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]24.38[/TD]
    [TD="align: right"]3.1[/TD]
    [TD="align: right"]24[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]25.69[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]26.89[/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE="width: 320"]
    [TR]
    [TD="width: 64"]Group B:[/TD]
    [TD="width: 64"]'115[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Engine Speed[/TD]
    [TD]Load[/TD]
    [TD]Cmd Pressure[/TD]
    [TD]Press @ Intercool[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [/TR]
    [TR]
    [TD="align: right"]0.35[/TD]
    [TD="align: right"]36.1[/TD]
    [TD="align: right"]1010[/TD]
    [/TR]
    [TR]
    [TD="align: right"]1.65[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.96[/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.17[/TD]
    [/TR]
    [TR]
    [TD="align: right"]5.49[/TD]
    [TD="align: right"]1040[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.8[/TD]
    [TD="align: right"]1320[/TD]
    [TD="align: right"]33.1[/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.21[/TD]
    [TD="align: right"]1520[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.41[/TD]
    [TD="align: right"]1920[/TD]
    [TD="align: right"]35.3[/TD]
    [/TR]
    [TR]
    [TD="align: right"]10.72[/TD]
    [TD="align: right"]2600[/TD]
    [TD="align: right"]45.9[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.92[/TD]
    [TD="align: right"]3680[/TD]
    [TD="align: right"]40.6[/TD]
    [TD="align: right"]1090[/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.13[/TD]
    [TD="align: right"]4120[/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.33[/TD]
    [TD="align: right"]2800[/TD]
    [TD="align: right"]13.5[/TD]
    [/TR]
    [TR]
    [TD="align: right"]15.74[/TD]
    [TD="align: right"]1080[/TD]
    [TD="align: right"]1020[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.94[/TD]
    [TD="align: right"]760[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.25[/TD]
    [TD="align: right"]55.6[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19.56[/TD]
    [TD="align: right"]3760[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.76[/TD]
    [TD="align: right"]1800[/TD]
    [TD="align: right"]24.8[/TD]
    [TD="align: right"]1030[/TD]
    [/TR]
    [TR]
    [TD="align: right"]22.08[/TD]
    [TD="align: right"]3000[/TD]
    [TD="align: right"]1120[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.58[/TD]
    [TD="align: right"]22.6[/TD]
    [/TR]
    [TR]
    [TD="align: right"]24.78[/TD]
    [TD="align: right"]800[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.09[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.31[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="width: 64"]STAMP[/TD]
    [TD="width: 64"] /min[/TD]
    [TD="width: 64"]°C[/TD]
    [TD="width: 64"]%[/TD]
    [TD="width: 64"] mbar[/TD]
    [/TR]
    [TR]
    [TD="align: right"]0.75[/TD]
    [TD="align: right"]14[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.06[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.36[/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.57[/TD]
    [/TR]
    [TR]
    [TD="align: right"]5.87[/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.18[/TD]
    [TD="align: right"]1400[/TD]
    [TD="align: right"]13[/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.59[/TD]
    [TD="align: right"]1640[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.92[/TD]
    [TD="align: right"]2040[/TD]
    [TD="align: right"]12[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.12[/TD]
    [TD="align: right"]3040[/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.32[/TD]
    [TD="align: right"]3880[/TD]
    [TD="align: right"]11[/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.53[/TD]
    [TD="align: right"]4160[/TD]
    [TD="align: right"]10[/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.73[/TD]
    [TD="align: right"]2080[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.14[/TD]
    [/TR]
    [TR]
    [TD="align: right"]17.36[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.67[/TD]
    [TD="align: right"]2120[/TD]
    [TD="align: right"]17.6[/TD]
    [TD="align: right"]1000[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19.96[/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.18[/TD]
    [TD="align: right"]94.5[/TD]
    [/TR]
    [TR]
    [TD="align: right"]22.59[/TD]
    [TD="align: right"]9[/TD]
    [TD="align: right"]1060[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.98[/TD]
    [/TR]
    [TR]
    [TD="align: right"]25.19[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.49[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.8[/TD]
    [/TR]
    [/TABLE]
    Can any one tell me what it is?
    Thanks in advance.
  2. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Coilpack... probably.
  3. Dani_B19
    9,343
    394
    Is the maf sensor a genuine one? Has none of the other codes come back?
  4. shaunf84
    shaunf84 New Member
    20
    Yes mate from eurocarparts and yes no other codes come back as yet.
  5. A3AH
    A3AH Member
    364
    13
    I got a MAF for my a3 from Audi specialists and it wasn't a genuine part so I would double check.
  6. Dani_B19
    9,343
    394
    If its not bosch then its not oem. Also it may be faulty, try and find someone local with a working one to swap with.
  7. <tuffty/>
    21,697
    4,124
    in block 003, its showing no airflow.. that suggests the MAF is is faulty, not plugged in or maybe has a wiring fault? N75 duty is non existent apart from a couple of blips...
  8. shaunf84
    shaunf84 New Member
    20
    Well it's plugged in, we're does this wire run to? Would it likely come loose at that end? The maf sensor wasn't changed that long back and it's been sat for over 12 month un used since I put the car back on the road it's been nothing but trouble different electronic bits going. Is there any way to test them? Also is it not likely to be the n75?
  9. shaunf84
    shaunf84 New Member
    20
    Anyone?
  10. <tuffty/>
    21,697
    4,124
    Could be a wiring fault although that normally shows up as an open circuit fault code or similar...
    Wiring goes back to the ECU...
    As for the N75, fix one issue at a time tbh... once you are getting airflow showing on block 003 for example then at least you know the MAF is working...
    Unusual for electrical faults the not throw a fault code... maybe its in limp mode and not using the MAF... not an issue I have seen as yet so tricky to know what to advise...
  11. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    have you tried swapping coil pack 1 with 2 to see if thew misfire moves? if so then its a coil pack, that would explain the fuel trim codes
  12. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Has it had Mice living in it chewing the wiring?
  13. shaunf84
    shaunf84 New Member
    20
    how do I get it out of limp mode?
  14. shaunf84
    shaunf84 New Member
    20
    shall try this tomorrow, but these codes haven't returned
  15. shaunf84
    shaunf84 New Member
    20
    I hope not lol
  16. shaunf84
    shaunf84 New Member
    20
    One thing I did notice when trying it disconnected it made no difference, but when I plugged it back in it was if it tried to cut out but didn't. So would you take this maf sensor back and get them to swap it? If that don't cure it trace the wire back to the ecu? Does this wire have its own plug going into the ecu or is it part of one connector being used for multiple runs?
    cheers
  17. shaunf84
    shaunf84 New Member
    20
    Anyone?
  18. shaunf84
    shaunf84 New Member
    20
    Took the MAF back for exchange and installed it, car still running **** juddering the same.
    But the:-16487 - Mass Air Flow Sensor (G70): Signal too High
    Fault has cleared in fact there are no faults found.
    I did a log of 3, 115, and 116 by error instead of 118 but if its needed i can rerun.
    [TR]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]Engine RPM[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD]%[/TD]
    [TD] °BTDC[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]0.82[/TD]
    [TD="align: right"]6.7[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]2.02[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3.23[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]4.64[/TD]
    [TD="align: right"]160[/TD]
    [TD="align: right"]13.3[/TD]
    [TD="align: right"]7.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]5.84[/TD]
    [TD="align: right"]9.89[/TD]
    [TD="align: right"]8.6[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]7.15[/TD]
    [TD="align: right"]1280[/TD]
    [TD="align: right"]8.81[/TD]
    [TD="align: right"]8.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.37[/TD]
    [TD="align: right"]8.72[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]9.57[/TD]
    [TD="align: right"]8[/TD]
    [TD="align: right"]7.1[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]10.77[/TD]
    [TD="align: right"]7.81[/TD]
    [TD="align: right"]15[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]11.98[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]13.28[/TD]
    [TD="align: right"]7.72[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]14.59[/TD]
    [TD="align: right"]9.78[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]15.81[/TD]
    [TD="align: right"]11.44[/TD]
    [TD="align: right"]33[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]17.2[/TD]
    [TD="align: right"]14.89[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]18.52[/TD]
    [TD="align: right"]2560[/TD]
    [TD="align: right"]18.17[/TD]
    [TD="align: right"]12.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]19.72[/TD]
    [TD="align: right"]36.19[/TD]
    [TD="align: right"]20.8[/TD]
    [TD="align: right"]36[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]20.94[/TD]
    [TD="align: right"]4520[/TD]
    [TD="align: right"]43.64[/TD]
    [TD="align: right"]20.4[/TD]
    [TD="align: right"]37.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]22.24[/TD]
    [TD="align: right"]2760[/TD]
    [TD="align: right"]4.67[/TD]
    [TD="align: right"]10.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]23.45[/TD]
    [TD="align: right"]8.83[/TD]
    [TD="align: right"]7.8[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]24.75[/TD]
    [TD="align: right"]7.97[/TD]
    [TD="align: right"]5.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]25.95[/TD]
    [TD="align: right"]8.17[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]27.26[/TD]
    [TD="align: right"]1200[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]28.46[/TD]
    [TD="align: right"]1600[/TD]
    [TD="align: right"]10.11[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]29.79[/TD]
    [TD="align: right"]14.06[/TD]
    [TD="align: right"]10.2[/TD]
    [TD="align: right"]34.5[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]31.1[/TD]
    [TD="align: right"]22.5[/TD]
    [TD="align: right"]14.1[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3600[/TD]
    [TD="align: right"]44.72[/TD]
    [TD="align: right"]22.7[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]33.71[/TD]
    [TD="align: right"]6280[/TD]
    [TD="align: right"]1.06[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]35.11[/TD]
    [TD="align: right"]3080[/TD]
    [TD="align: right"]7.58[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]36.31[/TD]
    [TD="align: right"]6.78[/TD]
    [TD="align: right"]6.3[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]37.63[/TD]
    [TD="align: right"]1160[/TD]
    [TD="align: right"]7.06[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]38.94[/TD]
    [TD="align: right"]7.22[/TD]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Load[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD="align: right"]1.22[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.42[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.73[/TD]
    [/TR]
    [TR]
    [TD="align: right"]5.04[/TD]
    [TD="align: right"]720[/TD]
    [TD="align: right"]71.4[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.25[/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.55[/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.77[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.97[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.17[/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.38[/TD]
    [TD="align: right"]31.6[/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.79[/TD]
    [/TR]
    [TR]
    [TD="align: right"]15.01[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.2[/TD]
    [/TR]
    [TR]
    [TD="align: right"]17.61[/TD]
    [TD="align: right"]2240[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.92[/TD]
    [TD="align: right"]2680[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.12[/TD]
    [TD="align: right"]60.9[/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.34[/TD]
    [TD="align: right"]4680[/TD]
    [TD="align: right"]1270[/TD]
    [/TR]
    [TR]
    [TD="align: right"]22.64[/TD]
    [TD="align: right"]14.3[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.95[/TD]
    [/TR]
    [TR]
    [TD="align: right"]25.15[/TD]
    [TD="align: right"]34.6[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.35[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.66[/TD]
    [/TR]
    [TR]
    [TD="align: right"]28.87[/TD]
    [TD="align: right"]1840[/TD]
    [TD="align: right"]39.1[/TD]
    [/TR]
    [TR]
    [TD="align: right"]30.19[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2920[/TD]
    [TD="align: right"]41.4[/TD]
    [/TR]
    [TR]
    [TD="align: right"]32.7[/TD]
    [TD="align: right"]4200[/TD]
    [/TR]
    [TR]
    [TD="align: right"]34.11[/TD]
    [TD="align: right"]5240[/TD]
    [/TR]
    [TR]
    [TD="align: right"]35.51[/TD]
    [TD="align: right"]2400[/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.73[/TD]
    [TD="align: right"]24.1[/TD]
    [/TR]
    [TR]
    [TD="align: right"]38.03[/TD]
    [TD="align: right"]30.1[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="width: 64"]Group C:[/TD]
    [TD="width: 64"]'116[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Fuel Correction[/TD]
    [TD]Lambda[/TD]
    [TD]Air Temp Corr[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD]%[/TD]
    [TD]%[/TD]
    [/TR]
    [TR]
    [TD="align: right"]0.4[/TD]
    [/TR]
    [TR]
    [TD="align: right"]1.62[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.82[/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.22[/TD]
    [/TR]
    [TR]
    [TD="align: right"]5.44[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.75[/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.95[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.15[/TD]
    [/TR]
    [TR]
    [TD="align: right"]10.37[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.57[/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.88[/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.19[/TD]
    [TD="align: right"]1360[/TD]
    [/TR]
    [TR]
    [TD="align: right"]15.41[/TD]
    [TD="align: right"]1680[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.72[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.12[/TD]
    [TD="align: right"]2520[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19.32[/TD]
    [TD="align: right"]2720[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.54[/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.74[/TD]
    [TD="align: right"]3720[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.05[/TD]
    [/TR]
    [TR]
    [TD="align: right"]24.35[/TD]
    [/TR]
    [TR]
    [TD="align: right"]25.56[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.76[/TD]
    [/TR]
    [TR]
    [TD="align: right"]28.08[/TD]
    [/TR]
    [TR]
    [TD="align: right"]29.37[/TD]
    [/TR]
    [TR]
    [TD="align: right"]30.59[/TD]
    [TD="align: right"]2360[/TD]
    [/TR]
    [TR]
    [TD="align: right"]31.9[/TD]
    [TD="align: right"]3120[/TD]
    [/TR]
    [TR]
    [TD="align: right"]33.21[/TD]
    [TD="align: right"]5600[/TD]
    [/TR]
    [TR]
    [TD="align: right"]34.62[/TD]
    [TD="align: right"]4040[/TD]
    [/TR]
    [TR]
    [TD="align: right"]35.91[/TD]
    [/TR]
    [TR]
    [TD="align: right"]37.23[/TD]
    [/TR]
    [TR]
    [TD="align: right"]38.44[/TD]
    [/TR]
    [/TABLE]
    That was just the car on the drive, but the air flow reading something but these reading seem way to low??
    Is it worth taking the car for a drive then re run vag com?
  19. badger5
    9,561
    2,029
    drive the thing if it will drive at all
    just revving it shows shag all. no load.. so no requested boost etc..
    you at least have some readings on airflow now.
    016 will show you misfires if its recording them, 031 will show fueling, 115 requested/actual boost, 118 actual boost n75% duty cycle, 020 timing corrections, 002 airflow and injector ms, 003 airflow and ign timing, 001 lambda adjust
    If its popping and misfiring look for misfire counter going up, and 031 fueling going >1.000 when on the throttle = lean misfire
    see what 001 says when warmed up, and what block 032 adjusts to.. DONT RESET faultcodes if you want to see it learn new values, as that resets the learnt adaptions and is has to start over.
  20. shaunf84
    shaunf84 New Member
    20
    Just took it round the block a few times to see if it was any better/I felt confident enough it would get me home if I nipped out to do some logs.
    Its still just as bad so came back, run vag-com and the below errors have come back.
    VCDS-Lite Version: Release 1.2
    Sunday, 24 February 2013, 17:46:41:0
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Coding: 10710
    Shop #: WSC 01236
    VCID: 3803ABE30B4B
    3 Faults Found:
    P0300 - 35-00 - -
    16686 - Cylinder 2: Misfire Detected
    P0302 - 35-00 - -
    P0118 - 35-00 - -
    Readiness: 0110 0101
    Address 03: ABS Brakes Labels: None
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FBDFB296F
    No fault code found.
    Address 08: Auto HVAC Labels: None
    Controller: 8L0 820 0
    VCID: AD2D0AB77409
    Note: Excessive Comm Errors
    Address 15: Airbags Labels: 8L0-959-655-AI8.LBL
    Controller: 8L0 959 655 J
    Component: Airbag Front+Seite 5008
    Coding: 01104
    Shop #: WSC 01236
    VCID: 45FDD2174CB9
    Address 17: Instruments Labels: 8L0-920-xxx-17.LBL
    Controller: 8L0 920 980 L
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 01444
    Shop #: WSC 19411
    VCID: 3C0BB7F33F73
    Address 22: AWD Labels: 02D-900-554.LBL
    Controller: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F31607F8EA5
    Address 35: Centr. Locks Labels: 8D0-862-257.LBL
    Controller: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15179
    Shop #: WSC 01236
    VCID: 2F1190BFFE05
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0B3A383735B
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 01236
    VCID: E5BDB2976C79
    Address 56: Radio Labels: 8D0-035-1xx-56.LBL
    Controller: 8L0 035 186 A
    Component: Radio D05
    Coding: 00013
    Shop #: WSC 01236
    VCID: 2C2B87B3CF13
    End --------------------------------------------------------------------------------------------------
    Coding: 10710
    Shop #: WSC 01236
    VCID: 3803ABE30B4B
    3 Faults Found:
    P0300 - 35-00 - -
    P0302 - 35-00 - -
    P0118 - 35-00 - -
  21. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Map sensor I say.
    Go put coil pack 2 on cylinder 3 and go out again, that will eliminate or confirm a coil pack issue.
  22. shaunf84
    shaunf84 New Member
    20
    which is cylinder 2? second from the right swapped with third from right?
  23. 16Klappe
    5,795
    1,186
    Cambelt side is 1 and air filter side is four (in basic terms).
  24. shaunf84
    shaunf84 New Member
    20
    Just swapped them over and been been back out, now its showing:-
    3 Faults Found:
    P0300 - 35-00 - -
    16686 - Cylinder 3: Misfire Detected
    P0302 - 35-00 - -
    P0118 - 35-00 - -
    So its swapped over. I also logged 16, 31, 115
    [TR]
    [TD="width: 64"]'016[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD]Count[/TD]
    [TD]Bin. Bits[/TD]
    [TD]Bin. Bits[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Marker[/TD]
    [TD]STAMP[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]1.71[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]3.12[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]4.33[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]5.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]6.84[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]8.15[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]9.35[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]10.76[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]12.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]13.27[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]14.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]15.8[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]17.09[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]18.4[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]19.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]20.91[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]22.13[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]23.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]24.74[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]26.05[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]27.34[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]28.67[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]29.97[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]31.28[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]32.48[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]33.69[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]34.99[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]37.61[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]38.82[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]40.02[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]41.24[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]42.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]43.75[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]44.96[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]46.16[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]47.38[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]48.58[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]49.79[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]51.09[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]52.38[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]53.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]54.91[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]56.22[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]57.42[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]58.73[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]60.04[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]61.26[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]62.46[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]63.85[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]65.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]66.27[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]67.58[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]68.79[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]70.01[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]71.41[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]72.71[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]74.02[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]75.32[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]76.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]77.84[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]79.06[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]80.35[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]81.55[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]82.86[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]84.08[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]85.28[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]86.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]87.71[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]89.12[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]90.31[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]91.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]92.94[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]94.14[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]95.34[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]96.65[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]97.96[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]99.16[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]100.56[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]101.78[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]102.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]104.29[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]105.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]106.7[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]108[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]109.23[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]110.43[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]111.74[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]112.94[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]114.14[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]115.45[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]116.65[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]117.96[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]119.27[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]120.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]121.88[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]123.11[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]124.29[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]125.72[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]126.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]128.23[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]129.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]130.75[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]132.15[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]133.35[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]134.56[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]135.87[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]137.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]138.29[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]139.58[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]140.8[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]142.22[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]143.42[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]144.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]145.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]147.45[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]148.74[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]150.04[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]151.35[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]152.57[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]153.78[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]154.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]156.29[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]157.51[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]158.8[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]160.02[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]161.22[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]162.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]163.73[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]165.04[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]166.33[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]167.55[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]168.77[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]170.06[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]171.28[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]172.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]173.79[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]175.1[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]176.31[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]177.61[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]178.82[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]180.02[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]181.24[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]182.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]183.73[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]185.06[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]186.37[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]187.67[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]188.88[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]190.19[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]191.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]192.7[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]194.01[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]195.31[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]196.6[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]197.84[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]199.13[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]200.33[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]201.64[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]202.95[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]204.15[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]205.37[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]206.57[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]207.78[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]208.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]210.2[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]211.4[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]212.61[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]213.81[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]215.01[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]216.34[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]217.54[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]218.75[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]220.06[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]221.36[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]222.65[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]223.96[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]225.18[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]226.4[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]227.6[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]228.89[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]230.11[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Disabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]231.42[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]232.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]233.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]235.13[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]236.34[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="align: right"]237.54[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [TD] Enabled[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="width: 64"]'031[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Lambda Factor[/TD]
    [TD]Bin. Bits[/TD]
    [TD]Bin. Bits[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="align: right"]0.81[/TD]
    [TD="align: right"]0.984[/TD]
    [TD="align: right"]0.945[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.22[/TD]
    [TD="align: right"]1.047[/TD]
    [TD="align: right"]0.953[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.52[/TD]
    [TD="align: right"]1.078[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.73[/TD]
    [TD="align: right"]1.062[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.03[/TD]
    [TD="align: right"]0.906[/TD]
    [TD="align: right"]0.961[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.34[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.55[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.87[/TD]
    [TD="align: right"]0.969[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.26[/TD]
    [TD="align: right"]1.023[/TD]
    [TD="align: right"]0.977[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.47[/TD]
    [TD="align: right"]0.883[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.67[/TD]
    [TD="align: right"]1.991[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.29[/TD]
    [TD="align: right"]0.992[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]17.59[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.8[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]1.008[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.33[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]22.63[/TD]
    [TD="align: right"]1.031[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.92[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.45[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.74[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]29.07[/TD]
    [TD="align: right"]1.086[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]30.38[/TD]
    [TD="align: right"]1.055[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]31.68[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]32.88[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]34.09[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]35.39[/TD]
    [TD="align: right"]0.938[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.81[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]38.02[/TD]
    [TD="align: right"]1.101[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]39.22[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]40.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]41.64[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]42.85[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]44.15[/TD]
    [TD="align: right"]0.867[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]45.36[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]46.56[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]47.78[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]48.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]50.27[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]51.49[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]52.8[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]54.1[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]55.31[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]56.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]57.84[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]59.13[/TD]
    [TD="align: right"]0.875[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]60.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]61.66[/TD]
    [TD="align: right"]1[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]62.86[/TD]
    [TD="align: right"]0.821[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]64.27[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]65.46[/TD]
    [TD="align: right"]1.842[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]66.68[/TD]
    [TD="align: right"]1.125[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]67.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]69.19[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]70.5[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]71.91[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]73.12[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]74.42[/TD]
    [TD="align: right"]0.828[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]75.73[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]76.95[/TD]
    [TD="align: right"]0.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]78.24[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]79.46[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]80.75[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]81.97[/TD]
    [TD="align: right"]1.788[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]83.26[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]84.48[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]85.7[/TD]
    [TD="align: right"]1.039[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]86.89[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]88.2[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]89.52[/TD]
    [TD="align: right"]1.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]90.71[/TD]
    [TD="align: right"]0.914[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]91.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]93.34[/TD]
    [TD="align: right"]0.891[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]94.54[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]95.75[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]97.05[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]98.36[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]99.56[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]100.96[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]102.18[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]103.38[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]104.69[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]105.89[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]107.12[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]108.42[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]109.62[/TD]
    [TD="align: right"]0.922[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]110.83[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]112.14[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]113.34[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]114.65[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]115.85[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]117.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]118.47[/TD]
    [TD="align: right"]1.608[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]119.67[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]120.89[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]122.3[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]123.51[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]124.71[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]126.12[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]127.33[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]128.63[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]129.84[/TD]
    [TD="align: right"]0.766[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]131.23[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]132.55[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]133.76[/TD]
    [TD="align: right"]1.944[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]134.98[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]136.27[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]137.47[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]138.78[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]140[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]141.21[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]142.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]143.82[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]145.03[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]146.44[/TD]
    [TD="align: right"]0.774[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]147.83[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]149.14[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]150.46[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]151.77[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]152.97[/TD]
    [TD="align: right"]1.016[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]154.18[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]155.38[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]156.69[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]158[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]159.2[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]160.42[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]161.62[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]162.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]164.13[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]165.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]166.75[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]167.95[/TD]
    [TD="align: right"]1.952[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]169.15[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]170.46[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]171.68[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]172.97[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]174.2[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]175.5[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]176.81[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]178.02[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]179.22[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]180.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]181.64[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]182.93[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]184.15[/TD]
    [TD="align: right"]1.312[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]185.44[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]186.87[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]188.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]189.28[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]190.69[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]191.9[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]193.1[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]194.41[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]195.73[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]197.02[/TD]
    [TD="align: right"]1.14[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]198.32[/TD]
    [TD="align: right"]1.109[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]199.53[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]200.73[/TD]
    [TD="align: right"]1.133[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]202.06[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]203.35[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]204.55[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]205.77[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]206.97[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]208.18[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]209.38[/TD]
    [TD="align: right"]1.226[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]210.6[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]211.8[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]213.01[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]214.21[/TD]
    [TD="align: right"]0.899[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]215.43[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]216.72[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]217.94[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]219.25[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]220.46[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]221.77[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]223.07[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]224.36[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]225.58[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]226.78[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]228.09[/TD]
    [TD="align: right"]0.86[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]229.31[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]230.52[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]231.82[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]233.13[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]234.33[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]235.54[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]236.74[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD="align: right"]237.94[/TD]
    [TD] [/TD]
    [TD] [/TD]
    [/TR]
    [/TABLE]
  25. 16Klappe
    5,795
    1,186
    You need a new set of coil packs then, and that will fix your problem.
    Phone your local dealer, give them the reg and ask them if it is due for a recall. They'll say yes or no, you might get a free set.
    Otherwise, order the TFSI coilpacks of Awesome GTI for £74.99 and run a 0.85mm plug gap like winners do.
  26. shaunf84
    shaunf84 New Member
    20
    Cheers Mate will do that, will this clear the below fault or is this a separate thing
    P0118 - 35-00 - -
    Thanks again everyone
  27. shaunf84
    shaunf84 New Member
    20
    also been reading a few posts RE the TFSI coil packs do they need the adaptor plates?
  28. 16Klappe
    5,795
    1,186
    Nope it's all just marketing poop to make the engine look pretty, they press in fine with no adapters.
    :beerchug:
  29. shaunf84
    shaunf84 New Member
    20
    Cheers mate, I'm only 15 mins away from awesome think ill go for some tomorrow, do they make a noticeable difference?
  30. Sam_
    Sam_ Down under
    3,038
    480
    If yours are busted, they will :)
