Hi, I had a calculation written down from a while back of how to calculate BHP from VCDS. With the engine off I had to record atmospheric Pressure which was 999.6 when I did it earlier. Then log (Engine, Block 115) Actual boost pressure; peak was 2601. Then deduct one from the other (1601.4) and multiply by .0145 to give PSI. Now the last bit I am not sure about and the answer I get is 23.2203, so that doesn't make sense. there is a file on the VCDS website about this calculation but apparently I don't have the correct software to read it so that was no help. Anyone shed any light on this.
Should have said the car is an B7, A4 Quattro TDI 170 with emptied DPF and a panel filter. It's going to get chipped on Friday so I was hoping to do a before and after kind of thing.
