Help with auto lock for windows from remote please
NME Jul 6, 2013
  1. NME
    NME Member
    150
    19
    Hi all,
    I have been trying to get this feature working from the remote, but it doesn't seem to want to.
    It shows as being active and "on" in VCDS, but still fails to open the windows or sun roof when the lock or unlock button is held on the seconds press and hold.
    These open if i insert the key and turn it and hold it in the lock or unlock position - but not from the remote.
    Any ideas on how to cure this, or as to what might be causing it?
    Its a 2011 s3 sportback if that helps.
    Thanks!
  2. NHN
    29,650
    1,799
    There does appear to be an issue with the coding for this feature which doesn't work, check your dis menu for any window options.
    Do not set to open as this will come back & bite you, when you sit on the key or kid etc presses buttons & the windows/roof open & then it rains or someone nicks something.
    NME likes this.
  3. NME
    NME Member
    150
    19
    Cheers Nigel, going into the DIS got the windows working, but not the sunroof - is that the limit of the option?
  4. NHN
    29,650
    1,799
    Try ticking box in module 09 for comfort closure of sunroof, see if it does that then.
