Help with a3 stereo saying safe
bearder2006 Sep 26, 2009
  1. bearder2006
    bearder2006 Member
    205
    hi ive got a 55reg a3 first thing what came up phone then says safe now and thats it any ideas thanks
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    You need to enter the security code, 4 digit code on the inside cover of the radio manual. If you don't have it then only a dealer can retrieve it for you.
  3. bearder2006
    bearder2006 Member
    205
    but its not asking for the number or how do i put it in thanks jay
  4. AndyMac
    9,832
    46
    No, you need to hold in the two entry keys to get the code input screen, which shows "1000" on the display, you then use the numbers 1 to 4 to enter the code i.e. if the code is 9876, then you press the "1" key 9 times to get 9, then the 2 key 8 times, the 3 key 7 times and the 4 key 6 times. You then press and hold the two entry keys again until the radio comes on. The process is clearly detailed in the radio manual. The two keys you need to hold in depends on the type of HU i.e. Concert/Symphony etc
    For Symphony it's the scan and RDS buttons IIRC
  5. bearder2006
    bearder2006 Member
    205
    will try it andy and will let you know thanks again its a concert
  6. bearder2006
    bearder2006 Member
    205
    done mate thank you it was scan and rds
