help with a white smoking 2001 a4 1.8t ??
motfree Jul 22, 2012
  1. motfree
    motfree Member
    464
    hey peeps
    im looking at buying an a4 1.8t but theres a problem with it ..
    the guy says its pouring out white smoke and that its the oil pump ..
    was wondering if anyone knows more or if it could be something else thats failed ?
    the engine code is AVJ and its done 100k
    any help much appriciated
    thanks
  2. HibiscusS4
    HibiscusS4 Member
    97
    More likely the turbo, I have never heard of a failing oil pump to cause smoke normally low oil pressure.
  3. jamie226bhp
    jamie226bhp Member
    468
    Turbo or just a worn engine causing oil to push past the rings,so unless its dirt cheap and u can do the things yourself don't bother
  4. jamie226bhp
    jamie226bhp Member
    468
    Having said that over filling with oil would cause it to smoke, seen a few numptys top up using a whole 4 litres
  5. adidasandy
    adidasandy Member
    271
    White smoke is surely water/steam? blue smoke is oil no?
  6. motfree
    motfree Member
    464
    See I thought white smoke would be head gasket ?? And seals on turbo would be blue .. I'm not that clued up on how things work to be honest but have a mate that will fit a new motor for £150. Aparently it's running 260 bhp But I do like a project :)So oil pump wouldnt make it smoke but would make low oil pressure ( warning light on dash ) ??
  7. Kingfisher
    Kingfisher Active Member
    267
    when Dialynx blew turbo seals ( on a TT ) at Castle Coombe a couple of years back it was white smoke with only a very slight hint of blue to it.
    260bhp..... must have a Garrett (?) turbo on it to make that sort of power.
    By the time the oil light comes on the damage has usually been done : (
  8. motfree
    motfree Member
    464
    There's no lights on the dash though that's why I'm confused ..
    Its running a k04 hybrid and high flow mani , big injectors , Fmic , full system and custom map
    But with no lights on the dash could that mean head gasket or turbo ??
  9. NHN
    29,331
    1,716
    Yeah loads of white smoke sounds like coolant normally no? So possible gasket or head, be very wary imho.
  10. Broken Byzan
    13,237
    465
    He could be refering to the oil cooler mounted on the oil pump feed housing. Thats can mix oil n water without the gasket being fubar.
  11. NHN
    29,331
    1,716
    Ah this is true, I have a slight issue with white smoke on startup, but thats another story.
  12. HibiscusS4
    HibiscusS4 Member
    97
    Burning oil gives a blue tinge but if there is enough it makes white smoke, see here a turbo diesel running on after turbo failure (the oil keeps the engine running after the fuel pump solenoid stops the fuel).
    epic diesel engine fail - YouTube
  13. adidasandy
    adidasandy Member
    271
    But that's a diesel engine NOT a petrol. The only white smoke I have ever known coming out of a petrol engine is steam / water.
    Diesel on the other hand can be a number of things like faulty or damaged injectors, incorrect injection timing (could be a worn timing gear or damaged crankshaft keyway), low cylinder compression (eg caused by leaking or broken valves, piston ring sticking, cylinder and/or ring wear, or cylinder glaze), cylinder head failure or gasket.
    So you need to make sure it is white smoke and not a blue tinge.
    TBH walk away unless you have over filled pockets or a spare engine as you could fix 1 problem only to find another one.
    Love the clip BTW, I have seen loads of Vauxhalls do that, the engine just runs off the oil inside of it and destroys itself. If it happens to you press brake firmly and stall the car before you burn your clutch out or / and blow your engine.
  14. HibiscusS4
    HibiscusS4 Member
    97
    Petrols struggle to stay running with large amounts of oil as it lowers the octane of the fuel but they will burn white smoke all the same.
  15. aragorn
    18,300
    805
    agreed, i had a 1.6 16v Vauxhall engine with cracked valve guides, that poured out white smoke.
    Smell will give you a good indication, burning oil smells quite different from steam!
  16. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Agreed I've managed to blow a couple of turbos (escort rs turbo and a legacy turbo) and it's always been clouds of white smoke not blue.
