Help with a turbo fault
B5NUT Mar 21, 2014
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,934
    732
    I know this is the B5 section but their is not much response in the A6 area, and there is a lot of knowledge here when it comes to turbo's
    The car is a 3.0TDI engine and this is what I found when I pulled of the intercooler pipes. The car has done just over 180K
    I think the seals have gone on the turbo and would like someone to confirm. So question is am I looking at a new turbo?
    There is also another thread where
    This was also the state of one of the inlet manifolds, think soot from the egr and oil mixed together must have caused this.
  2. Could be a stuck EGR valve. If the turbo was letting oil past the seals it would be very smoky from the exhaust, my 2.5 was.
  3. B5NUT
    3,934
    732
    Yer when you put your foot down it can be a bit smoky, but no blue smoke.
  4. That said, I haven't pulled the pipes off the intercoolers... My inlet manifolds weren't much different from yours tho. EGR blanked, manifolds cleaned, new gaskets and bottom end performance is restored. Open EGR seems to kill low end torque
  5. B5NUT
    3,934
    732
    Would love to kill the EGR, but cannot find a delete kit for my engine + I would need a remap (thinking about that anyway)....
  6. aragorn
    18,537
    865
    Oil looks normal tbh. It collects at the lowest point, and the pipe probably hasnt been off for years.
    The clag in the manifold is typical of most modern dervs, mostly due to EGR.
  7. B5NUT
    3,934
    732
    Thanks for the advice, yer I would say it's never been touched or cleaned in 8 years & 180K.
    Would an oil catch can help with this?
  8. It's not bad as it is, give it a clean and stick it back together (that's what I'd do anyway) if it's running right, enjoy it. eBay has loads of EGR plates, there is something you can do to fool the ECU into thinking the EGR is working. Sure I saw it on another thread.
    Mine (since the EGR blank) kicks out loads of black smoke if I floor it at low revs, when the turbo starts loading up it's like it's running on coal!! Could just be clearing everything that's built up...?
  9. B5NUT
    3,934
    732
    I would say it was around 150ml on the floor, and the intercoolers where well coated. Everything has now been cleaned/flushed in parts washer fluid, and will just have to keep an eye on thing, however now I know where the oil pools up I may put a drain hole, just drill and tap a hole and put a bolt in, and remove every few months.
  10. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,784
    2,629
    Is the car using oil ?, does it rev up on its own or do the revs hang, these can be signs the turbo is on its way out.
    A lot of that oil in the intercooler can be from the crankcase ventilation system and isn't actually from the turbo but at 180K it is possibly getting a little tired.
    Karl.
