Help with 1.8T Error Codes
joegraham Aug 17, 2013
  1. joegraham
    joegraham Member Audi A4
    33
    Hi
    I've got a A4 Quattro 1.8T thats is throwing some error codes.
    The first code up was:
    P1128 - Fuel trim: Bank 1 (mult) System too Lean
    This light started coming on intermittently and got gradually more frequent. The car seemed a bit down on power but other than that was fine. I bought a OBD2 scanner and cleared the code and it stayed off for a couple of days but the light came back on today.
    The scanner now shows 2 codes, the first one and a new one:
    P0011 - Bank 1: Camshaft A (Intake) Retard Setpoint not Reached (Over-Advanced)
    Now the car is struggling to idle, it is over-revving every few seconds. And the car seems very slow and sluggish. I haven't driven far but I also suspect my MPG is down.
    After doing some research on the internet I've found possible faults are a faulty Camshaft Adjustment Valve 1 (N205) or a faulty Fuel Pump Relay (J17).
    Anyone had any experience with these faults?
    Thanks for any help in advance :D
    Joe
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    But a faulty pump will cause both issues
  3. Chillout
    Chillout Active Member
    610
    50
    You could carry out actuator test with vcds for your vvt as for the lean code do you have a possible vac leak .
  4. joegraham
    33
    Thanks for the replies.
    Checked for vac leaks and didn't find any. However when I removed the pancake filter from the TIP I found it was blocked full of brown sludge so I cleaned this out before putting it back. Could this have caused one or both of the faults? Also is there any other places I should check for this sludge now that I have found it in the pancake filter? I believe its part of the PCV system??
    I cleared the fault codes after putting everything back together and have done about 20 miles since and the engine light hasnt came back on as of yet. The car also seemed to drive better with more power.
    Thanks again.
    Joe
  5. little ted
    little ted New Member
    My car had the same errors and sludge in the vac system .my fault was down to the crankcase breather valve.
    have a look at this thread on how to check the part and change it. the part was not dear from the dealers so it may be best to get one before you take it apart. also a couple of jubilee clips .I did mine and it didn't take long and I am no expert.
    hope this helps
    http://www.audi-sport.net/vb/a4-a4-...104028-crankcase-breather-valve-location.html
  6. joegraham
    33
    Thanks for the replies! I have replaced the valve as a precaution and the idle has been fine since. After clearing the error codes only the P1128 code has now returned.
    I have re-checked for vacuum leaks and still couldn't find any, however I noticed that you can hear the oil in the sump gurgling, is this normal when doing a vacuum test?
    The car is returning 25MPG which seems low even for a 1.8t quattro??
    Next step is to check the injectors, fuel pump and filter I guess?
    Thanks again
    Joe
