Help wiring facelift seats
wnjuk Apr 13, 2009
  1. wnjuk
    wnjuk Member
    108
    Hi, have required some facelift seats to go into my prefacelift 1.8T and have noticed that the airbag wiring is different. The seats are not heated. The wiring in my car is:
    Brown
    yellow/Brown
    Yellow/Blue
    On the new seats the wiring is:
    Brown
    Blue
    Brown/White
    Does anybody have any idea on which wires go where? I have searched but have not found a definate answer.
    Any help is much appreciated.
    Thanks - Wayne
  2. NHN
    29,295
    1,701
    Elsawin would be able to tell you which wires goes to which, if I get chance later I'll have a look for you, but doesnt it still have the original plugs on the seat & the car floor wiring so you can just plug it in anyway, cause even though colours are different, plugs should be same, dont recall them being changed, but then again this is VAG we're talking about.
  3. wnjuk
    wnjuk Member
    108
    Thanks! Yes the plugs are still attached to the seats but they are different and wont fit on the car loom. The new seats only have the one plug as where the old seats and have two.
  4. NHN
    29,295
    1,701
    images?
  5. wnjuk
    wnjuk Member
    108
    Give me 2 minutes!
  6. wnjuk
    wnjuk Member
    108
    Car Loom
  7. wnjuk
    wnjuk Member
    108
    Facelift seat plugs
  8. wnjuk
    wnjuk Member
    108
    Prefacelift seat Plugs
  9. wnjuk
    wnjuk Member
    108
    Anybody?
  10. NHN
    29,295
    1,701
    Sorry mate didnt get notice to say thread been updated, give me while as doing work.
  11. wnjuk
    wnjuk Member
    108
    Nah that's fine mate. Cheers for the help :salute:
  12. NHN
    29,295
    1,701
    Just looking through now, problem is different chassis show differnet wire colours, but they all commonly show Brown is definitely to earth so those 2 can be connected together, other 2 I am checking, whats your engine & gearbox codes on front of service booklet & do you know what car they came from?
    Do you have VCDS cause you could try the 2 wires one way & if it threw an error you know its the other way round, cut & use some blue bullet connectors if you want, this would be simplest way, but at your own risk, not had an issue or heard airbag going of to date with wrong wires
  13. wnjuk
    wnjuk Member
    108
    Engine: AGU
    Gearbox: DBZ
    They came from a 2000 1.6 sport
  14. NHN
    29,295
    1,701
    your year? also any idea of the engine & gearbox of other car?
  15. wnjuk
    wnjuk Member
    108
    Sorry, mines 1998. I'm finding out the info on the other car now. Give us a couple of minutes.
  16. wnjuk
    wnjuk Member
    108
    Not heard back yet. The guy might be at work. Been looking around and the engine code could be either AEH, AKL or APF, if thats any help.
  17. HTC
    HTC Active Member
    3,428
    9
    PM Prawn. He wired in a set recently.
  18. NHN
    29,295
    1,701
    I know the wires but your colour codes dont match up in elsa mate, as its only 2 wires just join & see if throws a code, you'll need vcds anyway to clear existing as it would throw one when seat airbag not connected, so have to clear them 1st, unlikely airbag will go of tbh.
  19. wnjuk
    wnjuk Member
    108
    I think that's what i'll end up doing, just trial an error. Thanks for your help
