Help!! Wide rims on rear? what fits????
ezachari Sep 18, 2006
  1. ezachari
    ezachari New Member
    I want to purchase a new set of wide lip rims for my 2001 A4 2.8. I want a wider chrome lip in the rear, but both front and rear to be 18". Please let me know what will fit and some rims to take a look at. I want tires that will ride smoother and take bumps better rather than handle corners.
    Thanks for any help.
  2. silver75
    silver75 Big Ron
    3,265
    8.5 will fit im sure with 235 tyres...maybe 9 with some arch work.
    BBS RS GT
    BBS LMs
    Rial Nogaro
    Rial Daytona two peace
    Keskin and Azev make a load of 2 piece deep dish alloys... depends on how much you want to spend
    If money wasnt an option I would go for some custom made HREs http://www.hrewheels.com/home/ :cool:
  3. Randomjim
    Randomjim Active Member
    2,752
    Im just about to order 2 9" wheels for the rear may need some arch work but i reckon it'll be ok. Got 8" at the moment and plenty of room.
  4. nomadx
    nomadx Member
    are you guys running wider rear tyres then? looking at fitting 235s on the back of mine, have 225s on the front
  5. Andy.B
    Andy.B Member
    401
    If any of you guys are running quattro i was told it was a big NO NO to run different width wheels on the rear to the front. FWD is no problem though.
  6. hiltoa
    hiltoa VAG erfahren
    298
    I'm running 245/40 17s (front and rear) on my B5 quattro sport avant with no issues... (apart from excessive grip!:yes:)
  7. naefeart
    naefeart Bonkers
    168
    39
    I thought the correct profile for 17s was 45, as in 245/45/17.
    If your profile is indeed 40, won't your rolling radius be out 5%?
    I'm about to move up to 18s and down to 40 profile tyres (225/40/R18).
    N
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    your issue is not the arches, especially on a quattro.
    9J wheels will only fit if you have a very low offset (which OK, requires the archwork).
    I have 8x18 running 240mm tyres and I have around 1-2mm between tyre edge and the top curve of the hub carrier.
    thats why they run ET20's on RS4's
  9. Jimbo.King
    Jimbo.King Active Member VCDS Map User
    269
    50
    You have to downsize profile because you gain it back when you go for a wider tyre.
    http://miata.net/garage/tirecalc.html
  10. hiltoa
    hiltoa VAG erfahren
    298
    What Jim said! ;)
