help: what oil do i use?
skanky Sep 12, 2006
  1. skanky
    skanky Member
    387
    okay im confused about what oil to use for my 1999 A3 1.8t sport. have scanned in the page from my manual but still none the wiser! (see linky)
    can someone recommend the type (VW 500 01?) and more importantly, a make of oil that is suitable, im on annual servicing if that makes any difference?
    http://img71.imageshack.us/img71/1939/audia3oilmanualgt1.jpg
    thanks!
  2. danneth
    danneth New Member
    26
    i also had this problem today i got the service light and oil came up where the mileage usually is so i just rushed to shop and bought some semi 10/40 now im reading about all these certain oils and stuff :S
    i also have a 1.8T (98)
  3. dummi
    dummi smoking a6
    1,210
    you need fully synthetic. after an extended period of using semi our fine turbo lines get clogged
    some fully synth 0/40 would be good, i think 10/40 is a little too thick on cold start, halfords do a reasonable one iirc. i'm on mobile1
  4. skanky
    skanky Member
    387
    can you recommend a brand to use? which mobil1 oil do you use?
  5. dummi
    dummi smoking a6
    1,210
    mobile 1 fully synthetic 0/40. bit pricey for regular changes i'm looking at alternatives for my next change
  6. dummi
    dummi smoking a6
    1,210
    oh forgot try asking opieoils , google them, you get a discount for being a member from this forum and good advice on oil for your application
  7. skanky
    skanky Member
    387
    cheers, have requested a password to get into the members section on opieoils..
  8. skanky
    skanky Member
    387
    i went to castrol's website and it gave me this info:
    so i would assume this one from opieoils is the same:
    ..as it seems i can get 5 litres of gtx for a little more than 1 litre of mobil1.. good/bad choice?
  9. YX1010
    YX1010 YX1010
    24
    I use Castrol Formula R 10W-40 and find it ALOT better than the previous oil i used (Mobile 1 full synthetic).
  10. dummi
    dummi smoking a6
    1,210
    go for it, use whatever is cheaper
    btw 5/30 is too thin for prolonged use same as they use in long life service, increased cam wear. optimum is 0 cold 40 warm
  11. skanky
    skanky Member
    387
    whats the main difference (advantage?) of using 0w-40 (mobil1) instead of 10w-40 (castrol gtx)?
  12. dummi
    dummi smoking a6
    1,210
    as far as i understand there are the usually slight differences between manufacturers product but not that great so any of the popular brands will be fine
    0/40 is thinner (0) on cold start up than 10/40 (10) so more chance for it to circulate through the turbo's on cold which is good, 40 it becomes that thick when warm which is a good thickness for wear rates. contact opieoils for more info they're very helpful.
  13. Tallpaul
    Tallpaul Member
    835
    Motul 8100 0w-40 Engine Oil. Cheaper and better than Mobil 1.
  14. dummi
    dummi smoking a6
    1,210
    ^^ what he says
  15. skanky
    skanky Member
    387
    did the "recommend me an oil" on opieoil's website so will wait to see what they recommend, but the motul oil, is this the correct one thats mentioned above:
  16. Tallpaul
    Tallpaul Member
    835
    Yup, E-Tech.
  17. YX1010
    YX1010 YX1010
    24
    Skanky - Magnet - I would either use MOTUL or Castrol Formula R
  18. skanky
    skanky Member
    387
    what about this stuff:
    ..is that the same as castrol forumla R? the spec sheet says forumla RS..
