Help! What have I broken??
Grant_H Dec 7, 2012
  1. Grant_H
    Grant_H Member
    49
    Hi guys,
    fiddling about getting the coolant hoses clamped up, and started the engine and some blue fluid leaked out of what looks like one of the injectors. I've managed to break off a braided hose that looks to connect each injector in series. DSC_0145.jpg
    What is this? Is it an expensive fix?
    Regards,
    Grant
  2. Bradderz_1988
    3,958
    238
    It may be the return pipe nipple or the feed pipe isnt quite sitting flush you are meant to replace the feed pipes if removed, you may get lucky and only have sliced the return pipe which is just 3mm id rubber hose.
