HELP!!! Warning symbol.
craig_TDI Dec 3, 2011
  1. craig_TDI
    craig_TDI Member
    90
    Alright everyone, was on my way to work this morning and my petrol light came on then a couple of minuets after this light appeared.. Can anyone tell me what it means please. Thanks
  2. kite
    kite Member VCDS Map User
    677
    DPF blocked, check your handbook
    Sometimes a drive at highish revs will clear the filter and the light will go off
  3. craig_TDI
    craig_TDI Member
    90
    Thanks alot, I'll give it ago.. What happens if it doesn't clear?
  4. kite
    677
    if it won't clear you'll have to take to a dealer.
    Might be worth scanning for faults if it won't clear.
  5. craig_TDI
    craig_TDI Member
    90
    Ok thanks alot... If I have to go to the dealer how much am I lookin at... Money wise?
  6. macpdm
    macpdm Member
    403
  7. rowdyboy
    rowdyboy Member
    804
    19
    I think to activate the cleaning cycle you have to drive at over 50 for 15 minutes, if I remember correctly.
    Someone on here was quoted £1500 from Audi when there's was blocked and needed replacing.
  8. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    here is a option on VCDS to do a clean cycle on the DPF.
    Best thing for now is to get it up to temp, go for a nice long drive at highish revs to someones house with VCDS.
    That should do it.
    I read somewhere that you have a couple of days to do the long drive, to clean/regen the filter before it is a trip to the stealers to get them to look at it.
  9. craig_TDI
    craig_TDI Member
    90
    Thanks alot for all your replys and help... I'll take it for a nice long drive and hopefully it'll disappear..
  10. craig_TDI
    craig_TDI Member
    90
    I took it for a drive out and did what the manual said but it didn't work.. Now iv got a flashing glow plug light, permanent engine management light and limp mode!!!!!! Not happy :( so seriously considering this permanent fix :) only problem is gettin my car from Manchester to Newcastle in limp mode..
