Help wanted
Jules Jun 27, 2011
  1. Jules
    Jules Member
    130
    Hi all i have just replaced my heater matrix on A4 B5 1.9 tdi 1997, right pain of a job, but the problem i am having is that I have no indicators no horn no outside tepmperature display fans will not stabilise. But i have a spare wire that has a brown cover on and it is a push on spade connector with a brown and grey wire which is a a permanet live, i thought it was to do with the heater controls so when I had all the dash out i laid it to the side with all of the other heater control wires but had nowhere for this connector to push onto. I have a picture of the wire which i will try and get up onto photobucket in the meantime.
  2. Jules
    Jules Member
    130
    In this picture below you can just make it out by the yellow box sat on the tunnel
    here is the cable when poked through the stereo apperture.
    Any ideas where this cable connects to?
  3. Bradderz_1988
    3,892
    230
    It's not for the ashtray light or glove box light is it ?
  4. Jules
    Jules Member
    130
    Nope got both of them sorted cheers
  5. griswold
    griswold Member
    347
    Im sure i got the same wire behind my stereo?
    I changed the standard headunit for aftermarket and im sure that is one of the cables left over?
    I'm sure somebody will know what it is.
  6. Jules
    Jules Member
    130
    Maybe it is but that doesn't explain the other bits not working, maybe if I plug in vagcom will this show any readouts? as i can get hold of one?
  7. Jules
    Jules Member
    130
    found some pictures on the net and it does look like the a stereo lead or power lead but as mine has a JVC cd player in there obviously not needed then so if anyone can help with the other problems then.
  8. aragorn
    17,816
    680
    Its just an earth for the stock head unit.
  9. griswold
    griswold Member
    347
    meant to add. probably not related
    get a vag com cable and scan it
  10. Jules
    Jules Member
    130
    Ran a vagcom scan and it threw up these error codes?
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 B
    Component: A4 KLIMAVOLLAUTOMAT_D72
    Coding: 04144
    Shop #: WSC 06325
    4 Faults Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    29-10 - Short to Ground - Intermittent
    00792 - A/C Pressure Switch (F129)
    29-00 - Short to Ground
    00532 - Supply Voltage B+
    07-00 - Signal to Low
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    anyone got any ideas on any of these?
  11. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    Its also an alarm trigger. if the alarm is armed and the HU is unplugged the alarm should go off :thumbsup:
  12. Jules
    Jules Member
    130
    also got no wipers as well, so there is obviously a electrical problem somewhere ???? but where do i start or look
  13. Jules
    Jules Member
    130
    Right then a mate of mine who is very good with fault finding diagnosed it down to the ignition starter switch, what i found weird was the fact that it would start but it would not supply the power to the electrics. £10.44 to replace form euro car parts, job done
  14. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    might be a stupid suggestion but have you checked the fuses?
  15. aragorn
    17,816
    680
    Thats because there are 3 or 4 different contacts inside the switch, which are used for different things!
  16. Jules
    Jules Member
    130
    I did check all the fuses and it was down to the ignition starter switch as above.
  17. Jules
    Jules Member
    130
    Cheers I know now
