help wanted from anyone mechanically minded
turboaudi Jan 8, 2007
  1. turboaudi
    turboaudi Member
    58
    ive just serviced my 96 18 turbo a4 cos she was running lumpy and seemed to stutter a bit when putting your foot down, i thought the service would have cured it , it has a little but it still seems to be a bit stuttery still and a bit ropy when you let it drop back down to idle , just wondering if there is any known cures or easy fixes from anyone who has had similar problems, any help and advice is greatly recieved:sos:
  2. Beerzo
    Beerzo Masa'warty 3200... Talk To Me!
    1,242
    Might be the MAF. There is a post on here to clean up the points for it that seems to solve some flat spot problems. Where are you based you could try and get one of the boys on here to scan your car with VAG-COM.
  3. Broken Byzan
    13,237
    465
    try removing the coil packs one at a time to see if it makes any difference. When you find the one that makes no difference swap it with one of the others to see if the problem moves. The coilpacks are a common failiure
  4. turboaudi
    turboaudi Member
    58
    ive tried the coil packs, didnt make no difference, i might try and clean the the connectors for the maf to see if that makes any difference , thanks for your reply lads:salute:
  5. marmite
    marmite Counting the Tesco Club points
    1,101
    Have you tried the ignitor box(poss wrong word) This is what supplies the signal to the coils
    It is located on the Airbox from memory and has 2 black plugs on it
    Held on with 2 8mm bolts
    They are common to go
    You can diagnois it by using a LED test light
  6. SteveS
    SteveS S6 avant
    691
    fuel filter? or possibly an air leak around inlet manifold or pipes?
  7. marmite
    1,101
  8. dummi
    dummi smoking a6
    1,210
    o2 sensors is another one, or any sensor , a check over with vagcom will help a lot
