Help VW POLO
john24susan Jul 27, 2007
  1. john24susan
    john24susan Member
    33
    Hi Folks, My Audi 2l TDI Sportsback is fine its my sons VW Polo front door, I know that this is not a Vw forum but the set up of the hinge assembly is very simular. The door was caught by the wind and has put the alignment out slightly , the door has dropped in relationship to the rear pannel, My son is sick as it is his pride and joy as it is a 56 plate.
    I want to know , How to remove the plastic inner bottom trim at the bonnet lever location? Do you have to remove the lever first ( if so how )? Or does the pannel slip over the lever ? When this pannel is removed will it give access to the inner hinge bolt ? I hope some one can help . Many thanks
    john.hynd1@virgin.net
  2. rodenal
    rodenal Active Member
    1,992
    How much has it dropped, if firm but careful u might be able just to pull the door back up
  3. RobinA3
    RobinA3 Well-Known Member
    1,825
    43
    go to www.clubpolo.co.uk for help
    i used to own and run that forum and its full of helpful people who know their stuff about the good old Polos
  4. john24susan
    john24susan Member
    33
    I have tried this but it will not move. It has dropped 2mm.
  5. marriedblonde
    marriedblonde Active Member
    4,371
    If you take it into a garage all they will do is force the door up. 2mm is not a lot...
