I have but there is no errors on license plate bulb or washer fluid at all! Is there anyway to RESET the ecu?
Below is the log anyway:
Saturday,09,May,2015,21:36:07:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 8E - Audi A4 B6/B7
Scan:
01 02 03 08 09 0F
11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX6A146097 Mileage: 279400km/173611miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 JD HW:
028 101 265 4
Component: R4 2,0L EDC G200SG 9643
Revision: --H01--- Serial number:
Coding:
0000072
Shop #: WSC
00048 210 91003
VCID: 6ED7CA8B0007
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Revision:
00000000 Serial number:
00000000000000
Coding:
0004401
Shop #: WSC
06335 000 00000
VCID: 285BFC93E263
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status:
00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 12
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x018A
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6CD3C083361B
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 K
Component: int. Lastmodul ECE 0504
Coding: 00001
Shop #: WSC 00220
VCID: 3A7F36DB0CCF
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M008H4HY
Coding:
0033622
Shop #: WSC
06335 000 00000
VCID: 3B7133DF03F5
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04021
Shop #: WSC 12345
VCID: 418D41376119
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 E HW: 8E0 920 951 E
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number:
00000000000000
Coding:
0004401
Shop #: WSC
54064 210 66681
VCID: 2C530083F69B
1 Fault Found:
01315 - Transmission Control Module
004 - No Signal/Communication
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBD1439FB315
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CA
Component: Komfortgerát T3B 3332
Coding: 06907
Shop #: WSC 00220
VCID: 72EFDEFB143F
Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0506
Part No: 8E2959801
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
1 Fault Found:
00955 - Key 1
35-10 - - - Intermittent
Address 77: Telephone Labels:
VCID: 55A585678591
Note: Excessive Comm Errors
End ---------------------------------------------------------------------
Thanks.
