Help! VAG CODE 00561 - Mixture Adaption limit not reached
imported_ChrisCardiffA3T Mar 14, 2005
  1. 00561 - Mixture Adaption limit not reached - Intermittent.
    Just had the car Vag'd last night... its been really hesitant, jerky, and missing occasionally.
    ...any ideas ideas???
    Chris /ubbthreads/images/graemlins/confused.gif
    Note:the car is an A3 1.8 T Sport 99 Jan
  2. Broken Byzan
    13,237
    465
    I had this and was advided it could be a vacuum leak. I checked all of my hoses and did a TBA and it's been fine ever since ( he says rushing for the closest bit of wood)
    I had the same symptoms too
  3. scoTTy
    scoTTy Active Member
    1,962
    Throttle Body Alignment (T.B.A.)
  4. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
  5. Right guys...thanks for the advice BUT!!!
    The car is throttle cable, and not fly by fire.
    A similiar fault occurred about 2 weeks ago which was rectified by a throttle body clean out 2weeks ago by audi...£195, now its reappeared and are now asking £500 for a new thrttle body and fitting...
    So it surely cant be TBA?
  6. HTC
    HTC Active Member
    3,428
    9
    Chris, I answered your question to this here --> CLICK
    BTW, you can do a throttle body adaption on a non drive by wire car. Did one on mine earlier in fact. Also the car automatically does this if you turn on the ignition and just leave it for a min. You can hear the throttle body moving about if you lift the bonnet.
  7. right guys... i do appreciate your advice, but no luck on the TBA...
    alas...looks like i'm heading for the dealer.
  8. Kevint
    Kevint Active Member
    1,182
    Could it be a Lambda probe problem?
    Kev.
