HELP!!! steering wheel ECU settings
gynads Feb 19, 2011
  1. gynads
    gynads Member
    314
    I have just fitted 1K0 953 549 AG a steering wheel controller from a golf GTi so as my MFSW function will work, I should of made a note of the settings before but like a balloon I didnt, can anyone give me the coding for an 07 s3 with MFSW cruise and RNSE. At the minute I have an airbag light, ESP fault and my steering is a lot heavier. Any help would be greatly received as I'm stressing out here!
    Adam
  2. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,381
    214
    VCDS should give you the code options when you open the controller ?
  3. hades-
    9,482
    646
    as above the helper box always shows up
  4. gynads
    gynads Member
    314
    Will that give me all the options for 4wd, and airbag etc etc
  5. gynads
    gynads Member
    314
    Coded it accordingly still no joy , stiill got air bag, ESP and steering faults
  6. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,415
    515
    Try THIS, might just need setting up.
    I once had a similar problem with various dash lights and stiff steering and it cleared it all up for me!
  7. gynads
    gynads Member
    314
    Cool thanks, I'll give it a whirl, what did you actually have to change on yours? The whole lot or just ABS/EDS/ASR/ESP (MK60) settings?
  8. -Ju-
    2,415
    515
    I think it was just the adaptation settings that worked for me, as soon as I went into them it automatically setup. My problem was slightly different to yours in that I plugged some new style clocks in and it messed everything up I never actually changed the coding.
  9. mike foster
    3,967
    These are the details I used and eventually it all worked !
    It's from a pm I sent someone :-
    These are the instructions your mate needs to follow for basic settings and also steering limit stop adaption:-
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    http://wiki.ross-tech.com/wiki/index...ial_Procedures
    http://wiki.ross-tech.com/wiki/index...g_Wheel#Coding
    When you code the steering wheel you may not have exactly those options but you will be able to see the choices that you need.
    Hope this helps
    Cheers ​
  10. gynads
    gynads Member
    314
    Right! i think i have sorted the steering and esp issue! but still cant get MF etc to work, this iss the fault code im getting back
    Saturday,19,February,2011,20:21:52:13314
    VCDS Version: Release 908.0
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Control Module Part Number: 1K0 953 549 AG HW: 1K0 953 549 AG
    Component and/or Version: J0527 036 0070
    Software Coding: 0003042
    Work Shop Code: WSC 01279 785 00200
    2 Faults Found:
    01426 - Controls in Steering Wheel (E221)
    004 - No Signal/Communication
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective
  11. mike foster
    3,967
  12. hades-
    9,482
    646
    01426 - Controls in Steering Wheel (E221): No Signal/Communication
    Possible Symptoms
    • Multi-Function-Display (MFD) can not be operated
    Possible Causes
    • Steering Column Control Module Supply Voltage insufficient
    • Fuse(s) faulty
    • Wiring/Connectors from/to Steering Wheel Controls faulty
    Possible Solutions
    • Check Steering Column Control Module Supply Voltage
    • Check Fuse(s)
    • Check Wiring/Connectors from/to Steering Wheel Controls
    Special Notes
    • When found in VW Golf/Jetta (1K): Steering Column Control Module
      • Check Fuse(s) SB2 (E-Box Low) or SB16 (E-Box High) in the Engine Compartment Fuse Box.
      • Check Connector T5k on the Steering Wheel Controls
  13. gynads
    gynads Member
    314
    I think i have sussed why my MF isno working! i need the harness adaptor thing! still got ABS light up but havent gone through these steps yet as my laptop battery died, Ive also still got the airbag warning light up and the horn doesnt work? but im wondering now if its because i dont have the harness? Anyone got one for sale!!
  14. mike foster
    3,967
    Do you mean you have fitted the airbag from a non-mfsw without changing the airbag wiring harness ?
    If so, go to Audi and buy one for £23 ! Ask for airbag wiring harness for mfsw.
  15. gynads
    gynads Member
    314
    No, I went from a poverty spec non MF steering wheel, to a FBMFSW a while ago, at the time not realising i had a 'midline' steering controller, so eventually got hold of this one and not thinking i'd need the harness, looking at other posts, it looks like that will cure all?
    Am i right in thinking 8J0 970 589B is the correct harness?
  16. mike foster
    3,967
    No !
    8J0 971 589 B
