Help S3 won't start
jemis Dec 31, 2010
  1. jemis
    jemis Member
    32
    Hi guys wondering if any of you guys can give many any ideas of what to check,
    The wife went out in it this morning to her mothers not even a mile away no problem buyt when she came back out it wouldn't start, being a typical women by the time I got there the battery was flat so I hooked up the jump leads and it is just spinning over making no attempt to start.
    The only thing I have checked sofar is the fuse for the fuel pump which is ok.
    Any help appreciated thanks.
  2. A3 Oly
    A3 Oly Member
    247
    potato inn the exhaust pipe? :D
    I had something similar before in my almera gti. altho i only started my car for 10 seconds to shift it out of way, when i attemped to start her later it wouldnt go and turned out to be engine flooding from the start then stop. prolly not that as she bin for a drive but i had aa out and all he did, to my shame was turn the key untill it started lol
    maybe worth charging her up and turning over till she starts. it sounded like it wasnt going to go but did eventually.
    Edit - thats my experience from a jap car dont waste ur time on that if one of the more knowledgable chaps has a better idea.
  3. jemis
    jemis Member
    32
    nah if anything its more like its not getting fuel but thanks anyway
  4. A3 Oly
    A3 Oly Member
    247
    I know what ur gonna say but is there any fuel in it PMSL.
  5. jemis
    jemis Member
    32
    haha its nearly full
  6. A3 Oly
    A3 Oly Member
    247
    lol sorry mate ive seen it before, i even managed to buy a car wich was suspected to be fecked but it turned out it needed petrol.
  7. colicabcadam
    colicabcadam Guest
    vagcom would help..... but failing that
    take the sparks out, see if they are wet, if they are, i doubt they are firing so you have an ignition problem, if they aint, you've prob got a problem with the the fuel supply.....
  8. colicabcadam
    colicabcadam Guest
    also, like already mentioned, it may have been flooded, not common, but it happens, if this is the case, simply leave the sparks out for a whilte on a radiator, you may also want to give them electrodes a clean with enry cloth / a wire brush (do it gently)
  9. jemis
    jemis Member
    32
    far too cold and damp for me to **** about so i've called the rac instead see what they find hopefully nothing expensive
  10. colicabcadam
    colicabcadam Guest
    womans way out! it;s always good to have a tinker yourself!!
  11. jemis
    jemis Member
    32
    not ideal when your trying to keep a 20 month old entertained at the same time though normally I would spend all day on it
  12. wibble111
    wibble111 needs to scratch the itch
    841
    Maybe an immobiliser problem if its turning over but not firing :unsure:
    Only way to be sure is to get it scanned and see what faults show.
  13. colicabcadam
    colicabcadam Guest
    maybe get the young one involved lol
  14. A3 Oly
    A3 Oly Member
    247
    Thats what i was thinking:
  15. DavidW
    DavidW Member
    211
    What he said, you don't have the flashing key symbol on the dash do you?
  16. AldebaranY
    AldebaranY New Member
    dont
    let
    me
    know
    What does it mean???
    "Help S3 won't start - Reply to Topic"
  17. jemis
    jemis Member
    32
    well rac guy turned up span it over, laid on the ground and punched the fuel tank then started it up, says there you go mate your fuel pump was sticking
    reckon i should purchase a new one or what
  18. A3 Oly
    A3 Oly Member
    247
    sweet lol, "RAC turned up and punched my car!" brilliant
