Help- S3 rear discs seized/corroded to hub and wont release, any suggestiions
sportquattro Mar 30, 2013
  1. sportquattro
    sportquattro Active Member
    845
    51
    Hi Folks
    Thought this would be an easy afternoon task, replacing rear pads and discs, got everything apart ok but the discs would not come free. Have tried heat, and a large persuading stick, but no joy. Any thoughs or does any one near Plymouth have a big hub pulller that would pull the disc off? Car sat on axle stands looking forlorne.
    Thanks in advance
    Nige
  2. Danny-boy
    Danny-boy Active Member
    511
    26
    I usually go with a metal lump hammer from the back of the disc.
    The shock frees it every time.
    If that don't work, pullers would be a mega mission.
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Might sound like a silly question but have you removed the little screw that secures the disc to the hub? I did a disc change on a mates merc and the screw head was covered in grime so we couldn't see it at all and thought there wasn't any. We went mental with a hammer and crowbar then found the screw after spraying about half a can of WD40 all over the disc lol. Unscrewed it and it just fell off. Won't make that mistake again!
  4. sportquattro
    845
    51
    Hi Westy, yes the retaining screw HAS been removed, I made that mistake 20 years ago, never again. Good call though.
  5. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    A suitable hammer will get it off, your just not trying hard enough lol
  6. Blackcupraa
    Blackcupraa Member Team Ibis VCDS Map User Audi S3 Manual
    193
    15
    Agreed, as you are replacing them a good thwack will release them, failing that spray WD40 (Or CD-90) at the back of the hub tonight and smack it in the morning!
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yep spray overnight and windmill in in the morning with a lump hammer
  8. sportquattro
    845
    51
    Well if at first you dont succeed, use a bigger hammer.. They eventually came off with a lot of whalloping with a lump hammer... many thanks to all for their help.
