Help!! S tron warning sign. Had it a day
JAAC UK
Ive had my s4 for a day now. Not even properly booted since owning it and a warning light has come on the dash. Bought privately 60 plate.
Sent from my SM-G925F using Tapatalk
Arghhh, doesn't bode well. Know anyone with VCDS to scan it to get a feel for what exactly could be wrong? If not, perhaps someone on here could scan it for you - whereabouts are you?
Reactions: V6_Man
Huddersfield at the mo
Oops! Looks like STronic issue Was about to suggest exactly what TechNick suggested. Whereabouts are you based, try VCDS map to find someone close to you for a quick scan to find out exactly.
It could be a simple drive range sensor as sometimes it can throw an error when it detects a missed shift. I'd do the scan first.
Reactions: TechNick
Anyone do a scan in Huddersfield?
I live in south london but need to get the car home
Private seller no chance, you're on your own I'm afraid.
I'd be getting it striahgt to some sort of VW/Audi specialist, not a main dealer. It's all good doing a VCDS scan but it won't fix anything mechanical.
Reactions: V6_Man
It turns off every now and again
Nightmare. Wonder if they just cleared the fault and sold it. :( As the others have said needs a scan to determine what's wrong. Might also be worth looking for a transmission specialist near you just in case. For example
http://3dtransmissions.com/
I believe these guys fixed @razza1 old S4.
Reactions: V6_Man
What's the symptoms? Have you lost gears with the error? Either odd gears or even?
Any clunking when going 2-1? Reverse engaging ok?
You can get an OBD reader and carista app to scan the codes
S4 MRC Stage 2+ gone
Stealth Black XFS now more sensible :)
Tbh i havent checked if it skips gears but it might be. Very slugish and slow
And it comes on and off
On and off when driving, or on and off when turning the car on and off?
On and off when driving but turning the car off does turn it off.
Will it reboot when you switch off, wait then switch on and clear fault. Had similar fault on mine but I had parked on a very steep drive been cleared for the last 6 months
Sent from my iPhone using Tapatalk Pro
Yeah its gone now. Drove about 5 miles today and been fine. Come on first thing this morn.
Would a vcds bring it up even if it gone off on the dash
I have Carista and autocom I'm in Queensbury if that's any use to you
So could be done cheaper private
I imagine this is a worrying time for you, and you're bound to have lots of questions driving around in your head. Realistically though, you're not going to know anything until the car's had a scan to diagnose what is actually wrong. Until then, everything about what might need doing, who could do it, and how much it might cost, is guesswork.
Reactions: gary_a4_quattro and skiptowncat
Yeah i know what you mean. Its like googling a pain in your foot. The internet will tell you you've got 24hrs to live. Getting it scanned thursday thanks to the vcds map
Reactions: jdp1962 and skiptowncat
