Help required with fault
coreythorny May 1, 2014
  1. coreythorny
    coreythorny Active Member
    463
    74
    Hi guys.
    Ive be had a fault on going for a while now. I've been led to believe it was the PCV valve. I've been getting the revs flutter after acceleration and going into neutral (see the video). I tested the PCV by removing the oil cap whilst idling and up to temp, you could clearly hear sucking and the car starting to miss.
    Ive vey just replaced the PCV for the new revision R version and changed the gasket. The car is exactly the same as before. My engine code is BHZ if that helps.
    Here re is a video of the rev needle showing how its hunting after accelerating:
    Audi S3 8P fault? - YouTube
    all help is appreciated.
  2. coreythorny
    463
    74
    My two options left are the check valve pipe work at the back of block or the vac pipes.
    Ill do the easier option first of checking vac pipes. Can anyone tell me the rough locations of them all?
  3. coreythorny
    463
    74
    I've ordered the check valve pipe and changing that in the morning.
    Does nobody have any suggestions?
  4. br4d5
    br4d5 New Member
    hi, I have the same problem, did you manage to solve this?
  5. TimWills28
    TimWills28 Well-Known Member Team Floret Silver VCDS Map User Audi A3 S-line owners group TDi
    1,196
    662
    Mine did this before... Check pipes..mine was split in front hence why I changed it...
