Help,Removing side light bulbs.
SootySport Dec 22, 2012
  1. SootySport
    SootySport Well-Known Member Team Silver
    2,785
    738
    The front ones. Do they pull straight out or are they on a bayonet type holder? tried twisting both ways and pulling but to no avail.
    Help
  2. Veedubnoodle
    Veedubnoodle Active Member
    223
    65
    They are the fiddliest things to do but just give them a wee tug if you can get a good grip on the wires and they should just pull straight out :)
  3. southylad
    southylad Active Member
    544
    Done mine last week mate take off the door on back of headlight remove main beam bulb and pull holder out of the way now get a pair of long nose pliers and get a grip of the sidelight holder and give a little turn up and down first you haven't got much room but you can just get a bit of movement on it now grip it and pull it out levering on the edge of the opening that did the trick for me hope this helps you mate I tried all sorts first and took some skin off my hands but once I had done it this way the opposite side was changed in 2 mins no probe, good luck mate
  4. TimG
    TimG Active Member
    942
    45
    Tip of a sharp knife to prise them out worked for me.
  5. grr666
    grr666 Member
    171
    19
    I'd say long nosed pliers as well, same type of holder
    as on the fabia I reckon Bernie. Can't check on mine, I don't have sidelights mate.
  6. SootySport
    2,785
    738
    Got them out now by Southylads method.
    Thanks for all the replies fellas.:yes:
  7. southylad
    544
    Glad it helped mate it had me stumped for a while on the first one I thought they were never gonna come out but once I got that out with the pliers the other side flew out cheers
  8. SootySport
    2,785
    738
    My mits are too big so give my Pit Crew instructions and with a bit of twisting and wiggling he got them out.
  9. southylad
    544
    I did take a bit of bark of my hands myself on the first one there is very limited space eh mate
