Help removing exhaust system
A3_Turbo Apr 22, 2009
  1. A3_Turbo
    A3_Turbo Swaying towards IHI....
    1,464
    Hi guys,
    Basically ive removed the downpipe etc from the engine so my whole exhaust system is kind of just floating about.
    I basically want to remove as much of this as i can and put it onto my anni golf.
    Has any-one got any tips for this?
    Im attempting to ermove my suspension,exhaust system, arb's and brembos this weekend!
    Jason
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
  3. A3_Turbo
    1,464
    I have the whole system still there including downpipe cat etc.
    I thought each section would be really hard to get out after the clamps are undone?
    Is it really that easy? Undo the exhaust clamps and each section slides out?
    Jason
  4. abdus
    1,827
    I would start from the rear silencer and work my way towards the downpipe. The parts just slide out of each other...(provided there is no welding) . you won't ebleive how easy it is (if you have some spanner knowledge...lol)
    If you have ramps, it will make life easier.
    check the link I've added in my first reply
  5. abdus
    1,827
    BTW, in the link above...it says there is cutting to be done. That's only on the standard exhaust which is one single part. Yours a Milltek (from your sig)...so they are in parts and no cutting needed
  6. A3_Turbo
    1,464
    Cheers thanks for that i'll get the car back on axle stands at the weekend and away i go :)
    Jason
